gotta know when to quit
Discussion in 'XJ Technical Chat' started by Polock, Apr 7, 2009.
  1. Polock
    i did everything i know, heat, impact driver even drilled a hole behind the bolt
    to get Kroil in there. Nothing, i give, it's staying on
    but i didn't snap it off so i guess i'll call it a draw 7 out of 8 ain't bad
  2. BikeRanger
    BikeRanger Member
    Dundas, Ontario
    vice grips tighten then loosen and repeat should start moving eventualy. dont reem on it just apply pressure one way then the other
  3. chacal
    Replace the entire head, that's the easiest way....... :D
  4. Polock
    maybe i'll try packing black powder in the cavity behind the bolt, now that i have a hole for a fuse :)
  5. switch263
    switch263 Member
    Austin, TX
    Give that kroil some time to work and give her another shot man. Kroil is like magic, love that stuff.
  6. dpawl31
    dpawl31 Member
    NH, USA
    Uhm, if it gets to THAT....
    Video please? :D
  7. SQLGuy
    SQLGuy Well-Known Member
    If you're planning to replace the boot, the one other thing I can think of is to weld a piece of bar iron, or a sacrifice allen key, to the bolt to use as a lever... you'd probably then need to cut the bar off after a half-turn or so, since there doesn't look to be clearance to rotate it 360 degrees.
    As an added benefit, the heat of the welding would help break the bolt loose.
  8. Polock
    the boot is actually in good shape but the engine is going to see a lot of stripper and harsh chemicals as soon as it warms up a bit, and i thought if i could get them off all the better
    i guess that one is just going to get taped up real good
    the cavity behind the bolt is full of Kroil and it sat over night
    there's really too much mass of aluminum there to heat with a torch and do any good
    i'll just give it a few smacks with the impact driver every day and see what happens
  9. wamaxim
    wamaxim Active Member
    Vancouver, USA
    I'm voting big time for the black powder/fuse option. Recommendation? Use lots and lots and lots of black powder. Use a long fuse stand back and don't forget to keep that video running!
    Good gosh Polock. You made my night!
  10. MiCarl
    Yep. You need a lot of heat fast.
    Black powder will do that :twisted:
  11. stereomind
    stereomind Active Member
    Tulsa, OK
    someone once mentioned using a drill with the clutch set to slip a bit and just let it hammer on the screw for a while... like a mini-impact.
    black powder sounds fun though!
  12. mcrwt644
    mcrwt644 Member
    Winchester, VA
    make sure you have a beer visible in your hand, then post to you tube!
    seriously though, it's weird she didn't come out. They are usually good about that
  13. midnightblu
    midnightblu Member
    Austin, TX
    no retreat no surrender! seriously man on things like this i get out the breaker bar and put slow gentle pressure on it and use somthing to hold it in place. tap the tool in lightly with the ball pin hammer. then increase the pressure and repeat. periodically try to tighten a little then loosen.
    you could do the same with a pen torch if needed.
  14. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Bring it to my house on Saturday or Sunday afternoon . We'll get it out!
    I gots big tools! :twisted:
  15. mrkil
    mrkil Member
    Toronto ont.
    heat is your friend
    throw some heat on the head where the bolt is
  16. bluepotpie
    bluepotpie Member
    Londonderry, NH
    i would grind the head off the bolt, remove the boot, and take it to a GOOD welder. They can use a special welding rod to weld a nut to it that will heat up the stuck bolt enough to almost liquify it, only for a fraction of a second. The flux from the rod cools faster than the steel does and creates a "straw" of sorts and as the steel expends it has nowhere to go but into the straw. as the steel cools, it contracts. Some of the steel will stay in the "straw" thus making the bolt slightly smaller in diameter than it was before. This pulls it inward, away from the threads, (by a TINY amount, we're talking 1/1000" or smaller) making it easy to throw a wrench on the nut and turn it right out.
