Guess what I'm going to do this weekend...
Discussion in 'Hangout Lounge' started by saftie, Mar 31, 2017.
  1. saftie
    New York, NY
    LeClairerog likes this.
  2. saftie
    New York, NY
    Yepp, that's an m-unit. Check out how small...
    Also ordered a wiring kit. Not cheap but gives me color coded wires in correct gauget etc
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Make teeny weeny shackles for the mice in your garage?
    and smoke.
    Ian Vanore likes this.
  4. saftie
    New York, NY
    Yes, but not in that order :)
    Stumplifter likes this.
  5. XJ550H
    mmmm have a smoke?
  6. saftie
    New York, NY
    When rewiring a bike from scratch, this comes automatically. (Un)fortunately I don't drink.
  7. k-moe
    Ooo! Ooo! Mr. Kotter! Mr. Kotter!
    You're going to scatter electrical terminals all over the garage floor.
    Ian Vanore, TomJ and Stumplifter like this.
  8. Stumplifter
    near Irma, WI
    OK - I literally Laughed Out Loud at this.
    That is something I would see myself doing - setting the tray open on the edge of something inappropriate and then Ooops! Catapulting tiny things everywhere!
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    The last two times I worked on my XJ in the garage I knocked my socket set tray on the floor. They roll everywhere and under everything.
    I also catapulted a spring from my gas cap latch into the darkness...later my wife found it on the laundry room floor, must have been in my clothes somewhere.
  10. kosel
    MInneapolis, MN
    Where'd you get the wiring kit? Just last night I was looking for something with correct color-coded wires. After I get my carbs taken care of, I'll replace the fusebox and fix the PO's bypass for the main fuse. Then, I'll also be moving the rear turn signals to the license bracket to make a little more room for saddle bags.
  11. saftie
    New York, NY
    I bought it at revival cycles where I got the m-unit.
    But I have seen the same kit on amazon, dime cycles etc. But not cheap. It's 80 bucks. But since I am doing everything from scratch, it's worth it to have all the different colors.
  12. kosel
    MInneapolis, MN
    I can live with that. I'm cursed with the gene that hates half-a**ing things. Or, as one of my favorite t-shirts says, "Fast! not Half Fast!"
    Joshua Preston likes this.
  13. saftie
    New York, NY
  14. Stumplifter
    near Irma, WI
    Shrink tubing and a hair drier, on the bus . . . . FZ
  15. Bmgalena
    Bmgalena Member
    Joplin
    Hope it goes well. I need to do the same. The previous owner removed the spedo and tac on my seca( which im ok with i think there kinda ugly) and made a horrible mess of the wiring. I can barely tell what is what.
  16. saftie
    New York, NY
  17. steber
    steber Active Member
    Scranton, Pennsylvania
    uhg.. I should just bring my bike to you when it comes to my wiring! o_O:confused:
  18. saftie
    New York, NY
    It's just practice and patience. Oh and the right tools. And enough cigarettes or beer like some people prefer.
    I'm ok now with following diagrams etc but still need help from forum when it comes to actually troubleshooting stuff. But I'm learning and this forum is a great teacher.
  19. Toomanybikes
    Tsawwassen bc
    Smokes or beer not both. I Forget which beer can is the ashtray:)
    BigT likes this.
  20. saftie
    New York, NY
    Ever thought about that maybe people having a beer or two while wiring is the cause of that? ;)
    Bmgalena likes this.
  21. saftie
    New York, NY
    Have a complete brain fart, as they say...
    The cable from starter solenoid to starter motor....
    That needs to go to the circled bolt, no?
    And ground is built in?
    Never had any doubts before, but for the last two days I just can't put it together how it was connected. I am 95% sure, but prefer to check with you.
  22. Bmgalena
    Bmgalena Member
    Joplin
    Yep. Thats the positive
  23. saftie
    New York, NY
    Thanks, I was certain of it but wanted double check before I break something.
    Spent a long time identifying stuff and reading diagrams to see what I can remove, what needs to stay. Putting everything together will be easier now that I know what goes where and how.
    Unfortunately, I only managed to extend my control wires. But it's OK, taking my time and have peace of mind later.
    BTW, took me 20 mins to get the old crimp connectors out of the connector housing on the rectifier wiring. The load wire melted a bit into the plastic. But all fixed now, new crimps are on. I'll do that for every connector on the bike. Only makes sense since I have everything apart anyway.
    That baby will be as good as new, considering that the engine is super low miles too (I'm actually thinking it is brand new)
  24. saftie
    New York, NY
    Still wiring in progress but I do have to say that the wiring kit was well worth the money. Having all the different colors makes it so much easier.
  25. saftie
    New York, NY
    Cool thing is that the wires all plug into the m-unit. So finishing that is easy. Just need to splice in the dashboard indicator lights.
    Up front I am still waiting for my new push buttons. But wires are already there.
  26. saftie
    New York, NY
    Quick question about the neutral switch:
    All it really does is open or close the connection to ground, correct?
    So I should run power to the dashboard light and from there, the ground wire runs through the neutral switch. And light will only go on if the neutral switch closes the ground connection. Ja?
  27. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    The alloy on the frame is so pretty. Oh to be able to weld like that, looks like a stack of dimes.
  28. k-moe
    Ya.
    saftie likes this.
  29. saftie
    New York, NY
    Bike is all wired now. Had some issues with turns not working but it turned out my cheapo turn signal no longer worked and had nothing to do with wiring.
    Now I need to finish up my newly designed tail frame in order to put the m-unit underneath the seat and finalize everything. Bike actually looks much nicer in person...
    Better flow with tire. It's 1 inch chromoly and not going anywhere when done.
    chacal likes this.
  30. Spaceweasel
    Spaceweasel Member
    Denver
  31. saftie
    New York, NY
    You have an electric gsxr? Electric as in runs on batteries?
  32. saftie
    New York, NY
    Everything test hooked up and working. Bike started up on the first button push. Only had to fix my turn signal indicator light on dashboard. I previously hooked up the wrong wire. All fixed now and finished it off with two diodes (one from each turn signal) to go into a single indicator light.
    This little box of black magic (m-unit) is great. The universal starter solenoid was worth the money too. It comes with an integrated fuse and 4 pins (2 fused, 2 unfused).
    rocs82650, Quixote and Stumplifter like this.
  33. saftie
    New York, NY
    Still need to draw up the new wiring diagram for future reference for me or any future owner.
  34. saftie
    New York, NY
    Frame done, need to build a new seat now plus have some anchor point welded on. Almost there
  35. saftie
    New York, NY
    Seat is back from upholstery.
    Frame is now with fabricator to attach a few mounting points, drill holes for switches and paint it
    chacal likes this.
  36. saftie
    New York, NY
    done and all is working. needs detailing now.
    i think my coolant system is acting up a bit. it is constantly pushing out coolant (water for now) but not sucking it back in. it may be the cap. it is original and worked, but it is on the replacement filler. possible that is my issue. anyway, still checking that. when i open the filler cap on hot bike, i should get a hissing sound but i dont. air leak somewhere.
    here pics of the bike. rides like a charm
  37. Spaceweasel
    Spaceweasel Member
    Denver
    Nice upholstery work - and that headlight looks pretty cool.
  38. saftie
    New York, NY
    Thanks.
    I wired it to turn the halo on and off. It's bright enough to serve as running light during daytime.
    The m-unit allows to turn regular headlight off.
    Tried taking pics of halo, but it's too bright for it
  39. saftie
    New York, NY
    Thanks Moe, I was thinking that at first too.
    The only place for one to form is below the thermostat. I did fill up fluid before connecting the thermostat to hose, but possible that was not enough. I'll do some research on how to fix this
  40. saftie
    New York, NY
    So...
    Opened the filler cap and let bike idle keeping an eye on the temperature.
    It pushed out coolant like crazy. When giving it throttle, coolant would drop, back (coolant) comes right back up when idling.
    At some point, the thermostat opens. I can actually see the coolant disappear and the temp on my display drop.
    So while the engine was running, I topped her off and closed the cap. Then turned off bike.
    So good so far?
    I will let the bike cool down and repeat this procedure. Let me know in case I am doing something wrong
  41. k-moe
    That's what I'd have done. I deleted my comment about a bubble in the system because I wanted to think it through a bit more. If there were a leak or a hole you'd see (and likely hear) coolant being evacuated from the system. If here were a bubble the system should eliminate that during when the engine is sitting as the coolant is drawn back into the system from the overflow tank (but that dosen't always happen). I'm really thinking that you are correct about the cap not sealing properly. It is possible for the cap to allow enogh pressure to build that coolant needs to escape to the overflow as it expands, but also have a small enough leak that low presssure can't form in the system as it cools.
  42. saftie
    New York, NY
    OR...
    I switched the T-connector around...
    Original setup, the return enters on top.
    In my new setup, it comes from below. I was thinking it would be ok since it would push it up into the radiator...
    I think it should not really matter as the cap blocks the overflow unless it opens, correct?
    So fluid should still get back into radiator.
    Thoughts?
    I'll check the cap tomorrow. For testing, I can use the one that came with the replacement filler (T-connector). Even though I don't know what pressure it is laid out for.
  43. saftie
    New York, NY
    I ordered a new cap and will test again when the part is here. Mine was ripped in two spots.
    I'll keep you posted.
  44. saftie
    New York, NY
    After a long time of coolant spill issues, it is finally fixed.
    It was air in the system hat i just could not get out. I fixed it by drilling a tiny hole into the thermostat that serves as an air bleeder.
    No more spills and no more feeling the fluid bubble inside the upper radiator hose. Temp was cooler in general too. I am still running distilled water, but I can now finally use regular coolant.
