handlebar xj750 seca
Discussion in 'XJ Technical Chat' started by cutlass79500, Feb 1, 2015.
  1. cutlass79500
    lawrenceville georgia
    Just got a seca 750. I want to swap out the bars for normal ones and put a regular master cyl on it when i put ss lines on it. I should be able to put a top triple tree off a 83 maxim 750 and run the maxim master get rid of the cable operated one behind the headlight. My 83 maxim has normal handlebars. Does anyone know a reason this would not work. I will measure the forks but they look the same size.
  2. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    Thats what I did. There are other posts here about this like adding just riser's with a long bolt beneath etc.
