head gasket repair
Discussion in 'XJ Technical Chat' started by katikyoo, Sep 16, 2009.
  1. katikyoo
    katikyoo New Member
    My 81 xj 650 ran rough when i bought it.pulled off the carbs and checked everything cleaned. Had no effect checked vaccum at the sync ports and found vaccum and compression. Guage bounced all over checked timing all good. through what i know now it has to be a blown head gasket and now i just need to know where to get a good quality gasket cheap. i would appriciate any help
  2. fastenova
    fastenova Member Premium Member
    Redmond, OR
    PM Chacal or look in the Forums | Supporting Vendor - XJ4Ever section.
    He has great prices, is responsive and knows more than I thought possible about these bikes. Oh yeah, and he ships via lightning bolts. =]
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Have you done a compression test yet? Check that before you take it apart. It can help determine what parts need repair.
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    I second Chacal, I have used his services many times and NEVER been disappointed
  5. bigfitz52
    +1
    I was going to suggest a compression test followed by a valve clearance check before assuming blown head gasket.
  6. katikyoo
    katikyoo New Member
    how doyoudo a valveclearance test
  7. JFStewart
    JFStewart Member
    Ontario Canada
    Search the forum for Valve Clearance. This topic has been discussed in previous threads in great detail. Its a topic that comes up frequently.
    Bigfitz has a posting "Airhead Valve Adjusting with pics"
  8. SQLGuy
    SQLGuy Well-Known Member
    I am currently repairing a bike where the PO concluded he had a blown head gasket, and had it replaced by a mechanic who tore the whole thing apart and put it back together never noticing that all four intake valves were bent. Needless to say, the new head gasket didn't help the bent valves.
    Although all four were bent, #3 was much worse than the others. I mainly found the issue by feeding compressed air into the cylinders at TDC. For #3 I had air blowing back out the carb.
