head light wiring
Discussion in 'XJ Modifications' started by ST0CKM0NK3Y, Sep 7, 2010.
  1. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    I want to install a round headlight on my 750 maxim but the oem square headlight had a nest of wires behind it. I wanted to know if the new round lights have a space in the back for all the wires or if i have to run them somewhere else? Ive seen a few of you guys with the round headlights and was wondering how you did it.. Any help will be appreciated. thanks guys.
  2. poprider
    poprider Member
    Seattle, WA
    I'm stripping it all back and hiding it along the frame.
  3. chacal
    Yes, all that wiring will fit up inside the round headlight bucket, too.......
  4. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    ok cool i just didnt want a bunch of wires all tangled up by the gauges. haha
  5. Cmccully04
    Cmccully04 Member
    State College, PA
    just remove the wires from the harness you do not intend to use.
  6. wizard
    A lot of bikes have the bunch of wires (& connectors) from each switch control running back under the tank, this is a fairly easy mod to do & worthwhile, as it can get pretty crowded in the bucket.
  7. Newbie
    Newbie New Member
    Gautier, MS
    yeah im doing the same but going with a 6 3/4" bullet style headlight. i took one look behind the stock light and said my god what am i going to do with all these wires. good post i need to know the same thing.
  8. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    ok sweet! thanks guys. Now i just need to get those damn gauges and a wiring diagram.. haha
  9. dan_betzing
    dan_betzing New Member
    Philadelphia
    Monkey, let us know how that works out. Ive been eyeballing the same switch but to a small round light but I wasnt sure where all those wires were going to go. Good luck!
  10. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    hey, so i actually went with the dual round buell headlights. I saw them on an older xj and became obsessed. hahah Ill post pics once i strip back the wire harness and tuck them all away.
