header pipes?
Discussion in 'XJ Technical Chat' started by carbineken, Jul 11, 2011.
  1. carbineken
    carbineken Member
    Wagoner, OK
    Do XJ's have double walled head pipes? I've got an awful rattle/buzzing sound coming from the front that I cannot track down. It happens from about 4800-5100 rpm. It's like a switch being flipped.....4800=BUZZZZZZZ....5150=sewing machine. And vibrates through the whole bike.
    An inner wall coming loose on one of the head pipes is the only thing I can think of.
  2. waldo
    waldo Member
    San Jose, Ca. 95125
    Yes they do if you tap the pipe you probably will be able to tell which ones are bad
  3. day7a1
    day7a1 Member
    San Diego, CA
    Yes they do...but that's not your problem.
    the 650j's are known to buzz at that rpm...you can minimize it by ensuring you have the fin vibration dampeners (little rubber pieces in the fins on each side of the motor), good rubber in the mounts, properly synced and valves adjusted.
    I'm willing to bet you are missing the dampeners...mine started to do it much more when I accidentally threw mine away :(
  4. carbineken
    carbineken Member
    Wagoner, OK
    Never even thought of that. I'll take a look for those dampers and check my donor bike for replacements.
    I was thinking head pipes because I had an issue with #2 breaking its studs off. I drilled and heli-coiled them and it seemed like the noise started shortly after that. At any rate I'll check the dampers.
    I've tried tapping the head pipes and couldn't tell anything from it.
  5. bigfitz52
    I can tell you this much, for sure: Once an inner pipe does start crackiing/breaking up, you'll start to see bluing on the outer pipe as a result of the hot gasses hitting it from inside.
    As for your rattle; day7a1 is right about 5000 RPM being the primary "buzz frequency" so anything that's loose is going to rattle and buzz at right around those RPMs.
    Other possibilities (stuff that's happened to me anyway) one or more head pipes loose at their lower clamp; or a broken rubber relay mount allowing a relay to rest against something and "sing" at certain RPM. Or for that matter, anything that's loose enough to rattle at the right harmonic frequency. I've had a small "harmonic buzz" driving me batty lately; turns out it's the plastic snap-clip on my tankbag's retaining strap "singing" against the front edge of the gas tank when it happens to end up close enough.
  6. carbineken
    carbineken Member
    Wagoner, OK
    As near as I can tell all the dampers are there. None of the pipes are turning blue. I've checked the lower clamps several times they are tight..that doesn't necessarily mean the pipes are tight inside them though. So I'll give that a look too. I may pull the gas tank off this weekend and run the engine up to 5000 and see if its anything under there. Got a busted Sporty I'm trying to work on and the wife is hounding me about her XJ hard to spend much time on the only running bike.
  7. ken007
    ken007 Member
    Brisbane, Australia
    gday, my bike runs very well, everything where it should be, at around 5000RPM mine gets a buzz in it but disappears soon after. it bugs the hell out of me cause on our highways the speed limits 100K/PH,exactly were it buzzes,so i go 95 or a 105,smooth as silk,but it still bugs me.
