headlight problem
Discussion in 'XJ Technical Chat' started by layedoutcosta, Apr 22, 2010.
  1. layedoutcosta
    layedoutcosta New Member
    well im new here with my first bike, its a 1982 yamaha xs400j, and when i got it theheadlight was messed up the guy PO told me there was a short in the killswith/start box, and if you jiggle the start button the lite would tun on, well thats what ive been doing, well now it aint working at all, and was wandering if anybody had any pointers, i checked the fuse it was fine, ive take the kill/start box apart and don see anything wrong, any help would be great
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    Have you tried to bypass it? At the very least you will understand where the problem is.
  3. layedoutcosta
    what exactly should i bypass, sorry that mite sound dumb, but im new to bikes
  4. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    First thing I'd try is cleaning all the connectors and check all the wiring for breaks... oh yeah, if you've been reading, get that fusebox swapped out too.....
    Thinking, the kill switch is on the opposite side of the light switches, so if you jiggle the wire and thing moving will be inside the "rats nest" mess of wires in the headlight bucket. You will need to brave it inside there, tidy it up. I wen in and cleaned up things . used twist ties to keep wire groupings together and fee up some room behind the light.... maybe he just has everything mashed together putting pressure on the connector to the bulb.
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Agreed with Za, check inside your headlight housing for bad connectors or something that it shorting out. Almost sounds like a bad ground somewhere.
  6. layedoutcosta
    on these bike, where is the ground? is it a common ground for a few diff things?
  7. ZaGhost
    ZaGhost Member
    1 on each side,
    1 from the negative battery terminal
    Other under the left side cover above the air box.
    With the bolt that holds the plastic play with the Reg/rect unit and TCI box
    Be sure they are tight, killed a reg/rect by having that one loose :/
