Hello all. Question for the know. My air cleaner case has 2 hoses aside the carb hoses. 1 in front
Discussion in 'XJ Technical Chat' started by fossilbike, Jun 22, 2017.
  1. fossilbike
    fossilbike Member
    converse tx
    One on bottom left. We're in the heck does the bottom hose go? I know the other hose is for ventilation system. But the other one has nothing about it in Manuel? Please help
  2. dkavanagh
    Rochester, NY
    Could you please let us know what year and model bike you have?
    Stumplifter likes this.
  3. fossilbike
    fossilbike Member
    converse tx
    My bad .83 xj750rk seca
  4. fossilbike
    fossilbike Member
    converse tx
    Sorry,. 83 XJ750rk seca
  5. fossilbike
    fossilbike Member
    converse tx
    It's not the hose with the union. It's the other one at bottom of housing. Haynes doesn't mention were it goes but they show the hose
  6. fossilbike
    fossilbike Member
    converse tx
    Haynes page 132
  7. fossilbike
    fossilbike Member
    converse tx
    Are you there?
  8. dkavanagh
    Rochester, NY
  9. fossilbike
    fossilbike Member
    converse tx
  10. fossilbike
    fossilbike Member
    converse tx
    Part #9 in that picture
  11. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    for drainage to street, any buildup of liquid ( whatever, oil, gas or water inside the airbox ) .......will drain to bottom underneath bike....
  12. fossilbike
    fossilbike Member
    converse tx
    Thank you for that answer. However the question still remains-why does the parts image show pinch clamps for both ends of the hose? Surely you wouldn't need that sort of clamp for the other end. Right?
  13. fossilbike
    fossilbike Member
    converse tx
    Mr.Kavanagh, were you able to come up with the answer? I thank you for your time it is greatly appreciated. Ken
  14. k-moe
    The bigger of the two goes to the crankcase breather. The smaller one just hangs down.
    The parts diagram only shows one clamp. The airbox drain hose is shown with a jagged cut, indicating that it is longer than the diagram can show.
  15. fossilbike
    fossilbike Member
    converse tx
    Thanks, I see that diagram you saw. It shows one clamp. Haynes page 132 shows 2 clamps. Each have a part #. 8 and 12. Who's right?
  16. fossilbike
    fossilbike Member
    converse tx
    Just wondering why there would be a drain stub on a intake vacuum?
  17. k-moe
    We are. As in us on this forum :)
    All of the service manuals have documented errors. That is one of them.
    TheCrazyGnat and REUBEN like this.
  18. k-moe
    There isn't one. Where are you seeing that?
    If you are referring to the airbox drain, it's because the oil mist and cold-startup condensation from the crankcase need to have a place to go to other than into the carbs. Airbox drains are very, very common. Your car even has one.
  19. fossilbike
    fossilbike Member
    converse tx
    Thanks man. I suppose the Manuel could be in error. And again were not talking about the hose that that connects just below the line of the intake adapters. THE OTHER ONE AT BOTTOM OF CASING.so you say this is a drain . Stub , hose ,clamp open drain. But wouldn't this drain suck in air? The answer is yes. Was that design taken in consideration for air jetting and performance?
  20. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Yes, they were very thinky when they designed these bikes.
    dkavanagh and k-moe like this.
  21. fossilbike
    fossilbike Member
    converse tx
    K-moe, no response?
  22. fossilbike
    fossilbike Member
    converse tx
    So not only does this drain , drain it also sucks in none filtered air straight to the carbs. What say you geniuses?
  23. fossilbike
    fossilbike Member
    converse tx
    Well thinky, why you suppose this drain sucks unfiltered air straight to the carbs?
  24. fossilbike
    fossilbike Member
    converse tx
    That's what I thought.
  25. k-moe
    My apologies for being busy taking care of household chores.
    Air does not get sucked into the airbox drain. I just confirmed this by starting my motorcycle and placing a bit of tissue below the drain hole. There is no airflow into the drain at any engine speed.
    If you have concerns, feel free to add a filter at the end of the drain hose. You may need to periodically remove said filter to allow the airbox to drain as intended.
    Your impatience and rudeness is becoming tiresome. Please tone it down.
  26. Stumplifter
    near Irma, WI
    What makes you say that?
  27. Stumplifter
    near Irma, WI
    You have proof?
  28. Stumplifter
    near Irma, WI
    Waiting. . . . .
  29. Stumplifter
    near Irma, WI
    That's what I thought. :D
    Rooster53 likes this.
