HELP! 2nd gear only grabs if i let off the throttle
Discussion in 'For Sale, Trade/Swap, Wanted' started by Custm85maxin, Jan 15, 2017.
  1. Custm85maxin
    Custm85maxin New Member
    Amsterdam new york
    HEY GUYS AND GALS!!!
    my 85 700 maxim is having a clutch or tranny problem....can anyone help....when i shift up into second and give it gas it just makes a slipping/slapping noise but if i down shift and use it to engine brake it grabs perfect??? is this my clutch that needs to be rebuilt or the tranny??? i aalready ordered the clutch rebuild kit but i want 2nd opinions!!
    Do one thing for us. Please make this THE thread for your machine. That helps up help you without missing or overlooking your questions.
    It never hurts to put a clutch into a used machine.
    When you accelerate:
    Does the tach speed up without an increase in road speed?
    Does the transmission pop out of second gear?
  3. Custm85maxin
    Amsterdam new york
    yes no accelration in road speed but the tach still rises.....amd no it goes into 2nd and stays there...like i said the clutch only grabs in second gear when im decellerating.....other wise all i get is revving and a sliding metallic sound.
    You diagnosed correctly then. New friction plates. Only do the steels if they are blue or warped. There is a how-to write up in the DYI section.
  5. Custm85maxin
    Amsterdam new york
    awesome!!! thank you very much i ordered everything new...theres almost 30k on the bike and i dont know when the last time the clutch was done so im going to do the full rebuild. friction plates, steel plates, springs, and a triple layer gasket
  6. k-moe
  7. Toomanybikes
    Tsawwassen bc
    Does it only do that in 2nd gear ? Does it work ok in 3,4,5 gear?
  8. XJ550H
    add clutch cable to the list
  9. quebecois59
    it sounds weird to me that the clutch would slip only in second gear, not sure the clutch iiself is the culprit.
  10. Custm85maxin
    Amsterdam new york
    3rd gear slipps when i gas it hard but like i said i doubt the clutch has been rebuilt any tome recently
  11. XJ550H
    could be a chewed up clutch basket
  12. quebecois59
    I would expect the 4th and 5th to slip too.
  13. Custm85maxin
    Amsterdam new york
    ill know when i see it lol...im tearing it down this weekend...a good basket is only like 20$ on ebay so not too worried there
  14. Custm85maxin
    Amsterdam new york
    i dont accelerate too hard in 4th or 5th but i coukd take it out tomorrow if its dry and see
  15. XJ550H
    just asking what kind of oil are you using
  16. Custm85maxin
    Amsterdam new york
    last oil change was done by a local bike shop...i believe it was yamalube
  17. XJ550H
    good just wanted to rule oil out as part of the problem
  18. k-moe
    Guys.... the clutch is most likely the original. It's due for replacement, slipping or not.
  19. XJ550H
    fully agree with the replacment of the clutch
    Just want to cover all the bases asking about the oil
    and to make sure he takes a good look at his basket
    quebecois59 and k-moe like this.
