HELP! bike wont start after switching out handlebars...
Discussion in 'XJ Technical Chat' started by Jasonmcgill, Oct 11, 2011.
  1. Jasonmcgill
    Jasonmcgill Member
    St George Utah
    Weird, i know, but i just got done switching out my handle bars and tried starting it up to take it out and now it wont start. i thought i was being careful enough when pulling everything off the bars but i guess not. i opened the head light and tried to make sure everything had a good connection but thats it, to the extent of my knowledge.
    Any help is appreciated!
    Thanks!
  2. Jasonmcgill
    Jasonmcgill Member
    St George Utah
    also checked the fuses, and also when you push the automatic starter button in it wont make a sound. nothing just like the bike is off.
  3. todd
    todd Member
    Irvine,Ca
    Are your new handlebars powder coated? The starter switch uses the stock chrome handlebars as a ground. I did the same thing to mine when I put my powdercoated clubman bars on.
  4. todd
    todd Member
    Irvine,Ca
    Either scrape some paint off where your starter normally will ground or run a new ground to your ground wires in your headlight bezel
  5. Jasonmcgill
    Jasonmcgill Member
    St George Utah
    ya they are black. im not sure if its powder coated.
  6. Jasonmcgill
    Jasonmcgill Member
    St George Utah
    so im pretty sure that was it, im grinding that paint off right now and ill be done shortly ill let ya know.
  7. Jasonmcgill
    Jasonmcgill Member
    St George Utah
    yup definitly it :) thank you so much. but now it just is revving itself when i turn it on im sure i just have to get the throttle to sit right in the little housing dealio but THANK YOU
  8. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    New+black usually means powdercoat. Definitely not a good conductor of electricity.
  9. RickCoMatic
    Check to be sure the Clutch Switch wire isn't pinched nor grounded-out near the Headlight.
