Help needed to identify some carb/motor o-rings
Discussion in 'XJ Technical Chat' started by KiD_Vicious, May 9, 2015.
  1. KiD_Vicious
    KiD_Vicious New Member
    Hello,
    I want to replace my old o-rigs (seals) from the throttle shaft of my carbs, and the supplier ask me to identify them on this link:
    http://www.cmsnl.com/yamaha-xj550rk-seca-1983_model8922/partslist/B-04.html#results
    As you can see, the resolution of the image is not in my advantage, but I supose that the o-ring that I need to buy is "nr.16".
    I attached 1 photo to be more specific in what I want to identify.
    Can somebody confirm that the o-rings that I must order are "nr.16" ?
    PS. : I ride my XJ550 Seca in Europe/Transylvania and I don't know if talking with "chacal" might help.
  2. chacal
    No, #16 is the fuel pipe o-ring(s), the throttle shaft seals were never serviced separate from Yamaha so they don't even appear on the diagram. We do have them available, (as well as the fuel pipe O-rings, which you'll also want to replace while you have the rack apart).
  3. KiD_Vicious
    Thank you for your reply.
    Can you provide prices for a set of throttle shaft o-rings, a set of fuel pipe o-rings, and a front brake sight glass replacement kit. For the front brake sight glass replacement kit I previously sent a PM (conversation).
    Sorry for my bad English :)
