HELP!! New seca 650 Turbo, Bost Sensor hose.
Discussion in 'XJ Technical Chat' started by MazdaRX7Fan, May 28, 2008.
  1. MazdaRX7Fan
    MazdaRX7Fan New Member
    Oklahoma City, OK
    Just bought a Seca 650 Turbo ('82 that is) tearing a few things apart to fix stuff, and there is a "boost sensor" under the Air cleaner/Battery area, the sensor has a long 1/4 inch (6-7mm) I'm guessig on size) hose coming off the sensor (Small electronic looking doo-hickey with a couple of wires coming off of it) need to know what the hose should be connected to. Not sure if this makes any diff., but the tank has a plain old "ON"/"RES"/"OFF" petcock, no "PRI" on it anywhere, reminds me of my old '76 honda 550.
    TIA
    MazdaRX7Fan
    P.S. if ya know where it goes, and can post a pic, I'd be eternally greatful! :D
  2. chacal
    The petcock on the Turbo models is not vaccum controlled, so that is correct..........
  3. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Hose connects between the carb and head.
  4. MazdaRX7Fan
    Oklahoma City, OK
    Richard,
    I took a pick, is this where the boost sensor should be connected? don't know if the pic is going to post (new to this stuff too)
    not working, lemme figure out how to do it.
    O.K., can't figure it out, ... there is a small hose just on the front of the carbs, between 1 and 2, is that where it goes? there's already a small hose there connected to the surge tank just above the #3 joint to the carb.
    Paul
