HELP: Rebuilt turbo carbs and have an extra plastic washer
Discussion in 'XJ Technical Chat' started by farmer, Mar 5, 2013.
  1. farmer
    farmer Member
    Hi,
    I recently rebuilt my Seca Turbo carbs and have this extra plastic washer/spacer. I am going to guess it goes in somewhere between one of the throttle shafts, but where? Any ideas ? Thanks guys
  2. 750E-II_29Rbloke
    South Cheshire, UK
    yup, that's one of the throttle shaft washers that goes between the circlip and seal ;)
  3. bigfitz52
    or on the outside of any of the carbs between the seal and the linkage.
    TWO of the possibilities (outside on 1 and 4) are an easy fix; the rest are either a pain (break the rack again) or a real pain (if butterfly removal necessary.)
  4. 750E-II_29Rbloke
    South Cheshire, UK
    True, I omitted that side of them. That would be a pain if it is from inside :?
  5. mtnbikecrazy55
    JeffK might be able to provide further insight to narrow it down, he has a few turbos iirc.
  6. 750E-II_29Rbloke
    South Cheshire, UK
    Re: HELP: Rebuilt turbo carbs and have an extra plastic wash
    Can't really narrow it down any further than that without looking for the carb it's missing from?
  7. chacal
    Mikuni carbs used the plastic shim washers only on the side of the shaft that does NOT have the return spring.
    Here is the order in which the various bits-and-piece are arranged on the 650 Turbo carbs:
    OEM Mikuni throttle SHAFT #1:
    Outer
    E-clip HCP6836
    Plastic washer: HCP6837
    Thin metal shim: HCP39B
    Shaft v-seal: HCP6838B
    Butterfly Valve on shaft: HCP14270
    Butterfly Valve screws: HCP5898
    Return spring: HCP13628
    Throttle shaft bracket arm (swedged): HCP14266
    Inner
    XJ650 Turbo
    OEM Mikuni throttle SHAFT #2:
    Outer
    Throttle shaft bracket arm (swedged): HCP14267
    Thick metal spacer: HCP14273
    Return spring: HCP13629
    Butterfly Valve on shaft: HCP14321
    Bracket arm (removable): HCP13679
    Bendable washer: HCP13685
    Nut: HCP13681
    Inner
    XJ650 Turbo
    OEM Mikuni throttle SHAFT #3:
    Outer
    Throttle shaft bracket arm (swedged): HCP14268
    Plastic spacer: HCP14272
    Bracket arm (removable): HCP14271
    Lockwasher: HCP13682
    Nut: HCP13681
    Return spring: HCP13630
    Inner
    XJ650 Turbo
    OEM Mikuni throttle SHAFT #4:
    Outer
    E-clip HCP6836
    Return spring: HCP13631
    Throttle shaft bracket arm (swedged): HCP14269
    Inner
    XJ650 Turbo
  8. 750E-II_29Rbloke
    South Cheshire, UK
    Did you mean the NON-return spring side? that's what the specs say, in which case shouldn't be as bad of a mistake to fix.
  9. chacal
    Bloke, you are correct! I fixed the wording on my posting above. Thanks for the sharp eyes!
  10. 750E-II_29Rbloke
    South Cheshire, UK
    No worries, I'm thoroughly entrenched in carb-spec spotting mode at the moment having to search for HSC33's to fit my new XJ750E-II that nobody except you and Wolfie seem to have heard of! 8)
    By the way, exactly how rare IS this model, do you know how many made/left etc please, I like my new toy, I like to be different, I like rarities. Even if parts can be a PITA :wink:
  11. farmer
    farmer Member
    I should have clarified that its the thick plastic washer not the thin ones. Plus there is only one of them so I am going to say it goes on the 3rd carb.
    Thanks again guys.
