Help Removing Pivot Shaft Bolt From Swingarm
Discussion in 'XJ Technical Chat' started by Jmkrull, Feb 8, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    Hey all, Just wondering if anyone has any tips on removing the left-hand side 27mm Pivot Shaft Bolt from the swingarm (The side with the lock washer). I tried to get it to budge, but couldn't with an 18" socket wrench. Is there a trick to this, is it a left hand threaded bolt, idk? Thanks!
  2. hogfiddles
    Did you remove the flat locking-tab washer? Regular counter-clockwise thread, it's probably just seized-----soak it with kroil, or ATF/acetone, or your favorite rust-busting penetrating concoction. I use a socket on the ratchet or a breaker bar as needed.....and persuade it with a hammer on the handle if necessary
  3. Jmkrull
    Jmkrull Member
    Minneapolis
    I bent the tab back as the Haynes said, but if it comes off completely, I’m at a complete loss on how it’d be possible. It’s kind of a weird thing that just makes things difficult. You can’t get a socket in terribly deep because of it and im worried I’m gonna round the thing off.
    Just out of curiousity, I hit it with a torque wrench and it clicked maxed out, so something is up. I figure I’m doing something wrong.
    I’m thinking regular box wrench, socket side with the outward bend and slipping ye olde pipe over it. Just wanna make sure I’m not going to completely cross over in “you’re screwed” territory first.
  4. hogfiddles
    You've bent the tab out like you should. Put your socket over it, put your breaker bar on it, start smacking it with a hammer
  5. XJ550H
    you could use the weight of the bike by using a breaker bar and a small floor jack bring it up a little then sit on bike.
  6. Jmkrull
    Jmkrull Member
    Minneapolis
    I just broke my socket wrench on this with a huge pipe on it. Can’t use the weight of the bike at this point. Am I missing something?
  7. hogfiddles
    You're missing a better socket
    Nuch likes this.
  8. XJ550H
  9. Jmkrull
    Jmkrull Member
    Minneapolis
    On it. I’m gonna have a buddy help me hold things tomorrow. Ill let you know how it goes! Thanks again
  10. Polock
    i'd put some heat on it, but i put heat on everything :)
  11. Jetfixer
    An impact socket is beefier .
  12. XJ550H
    I think he was refering to his ratchet and not the socket. Rachet teeth break easy when you put a pipe on them
    but yes I do use impact sockets as my standard socket unless they are to thick to fit where I need it to work
  13. hogfiddles
    Ok, you're missing a better socket AND a better breaker bar
    XJ550H and Chitwood like this.
  14. Jmkrull
    Jmkrull Member
    Minneapolis
    Got it! I had a 27mm impact socket and got a breaker bar. Had a buddy put his weight on the head of it over the nut while I pulled. Flexed the breaker bar, still didn’t budge. Ended up slipping a pipe over that, put all my weight in it and the nut broke finally, crying on the way out. Holy hell, man. That was intense.
    Plug likes this.
  15. k-moe
    Get you a impact gun to go with that socket.
  16. joe elliff
    joe elliff Active Member
    illinois
    I love my Matco air impact.
