help starting gsxr 750 1986
Discussion in 'Other Motorcycles' started by beanflicker_98, Sep 27, 2006.
  1. beanflicker_98
    beanflicker_98 Member
    east petersburg pa
    I recently got a gsxr.the po was using either to start it.I brought it home and found the #1 plug wire kinda of beat up,so i trimmed it expsoing some nice looking wire then reinserted it back into the the cap you put over the spark plug and she started with no trouble for about a month.sunday i go for a ride and she runs great.yesterday i take it out to go to work and and it starts but doesn't stay running.It doesn't sound like it is either getting fuel or isn't getting spark to all four plugs.I sprayed some starter fluid thru the air intake carb boots,it will start for a few seconds then bog out and die.can't figure it out.any help would be great.Thanks john
  2. Joel07
    Joel07 Member
    Durham, NC, USA
    9 times outta 10 it's in the carbs. Have you taken them off and cleaned them? Is there a fuel filter between the petcock and carbs?
  3. beanflicker_98
    east petersburg pa
    no fuel fileter and no I have not cleaned the carbs.Hep
  4. Joel07
    Joel07 Member
    Durham, NC, USA
    How old is the fuel in the tank? Could just be a case of water in the gas...
  5. beanflicker_98
    east petersburg pa
    fuel is fresh took it for a 50 or so mile ride the day before and everything was working great.Parked her overnite and she wouldn't stay running.
  6. chevy45412001
    chevy45412001 Member
    illinois
    carbs or fuel injected? fuel pump?
  7. beanflicker_98
    east petersburg pa
    its got carbs.I beleive the reason for the bike not starting is the petcock is missing the metal bit that enables me to set it to a prime position.i shot some starter fluid into the carbs and it stats and runs again.I reckon I need to get a new petcock.Thanks for the interest.
