Help with rear brakes
Discussion in 'XJ Technical Chat' started by Igor, Jun 26, 2010.
  1. Igor
    Igor Member
    Santiago CHILE
    I´m having problems with my rear brakes, they seem to lose the regulatión to the point that they get stick and completely stop the bike
  2. skills4lou
    skills4lou Member
    Dillon, MT
    Remove the wheel and check for delamination (separation of the shoe material from the steel mounting plates). It's fairly common on older bikes, and especially on XJ's. The next place to look is the pivot points. Take 'em all apart, clean everything and lube the points that are supposed to get some grease (brake grease ONLY, not chassis grease).
  3. Igor
    Igor Member
    Santiago CHILE
    Thanks I will do it
  4. Polock
    your brakes might be worn out, once the cam that moves them goes too far the brake springs can't pull the brakes back
    that can get you a wheel lockup at the worst time
  5. cutlass79500
    lawrenceville georgia
    i have a feeling your brake shoes are wore out. ive seen this then they move the lever back on the spindle that comes out of the rear drum if im correct the expander is going to far and trying to go back down the otherside wich is making the brake stick
  6. Igor
    Igor Member
    Santiago CHILE
    I thank all of you for your help, today I will check it out
