Help with this wiring diagram
Discussion in 'XJ Technical Chat' started by timbojim, Aug 14, 2011.
  1. timbojim
    timbojim Member
    Kelowna, BC, Canada
    I'm planning to do rewire, and while looking at this minimal wiring diagram, I realized that there are no turn signals anywhere on it. Either that or I'm blind. Does anyone know of any minimal wiring that includes turn signals? Thanks ;)
  2. SQLGuy
    SQLGuy Well-Known Member
    No, that's correct. This is the one that also doesn't have a horn. It's minimalist to the point of being illegal is most states and countries, but a lot of places don't do annual inspections....
  3. dwcopple
    dwcopple Active Member
    bay city, michigan
    add a horn off the fuse box. wire to hot ground to button other side of button completes ground for horn to sound. We don't need stinkin' signals, that is why we have hands!!!
  4. SQLGuy
    I'd rather have my left hand available for the clutch.
  5. timbojim
    timbojim Member
    Kelowna, BC, Canada
    I dont really care about the horn. its more the signals. signals are obvious if they're not there, but a horn? meh.
  6. waldo
    waldo Member
    San Jose, Ca. 95125
    No tail light when in the on position either
  7. darkfibre
    darkfibre Member
    Perth, Australia
    Try something like this;
  8. SQLGuy
    Yes there is. It's on for "On" and for "P".
  9. waldo
    waldo Member
    San Jose, Ca. 95125
    Not in that diagram it isnt. Tailight is only energized when in (p) its not even connected to the (on) circuit
  10. SQLGuy
    Look at the symbol for the ignition switch compared to the symbol for the symbols for the dimmer or brake switches. Notice how the ignition switch has a large, curved, contact, rather than a point one? That's because the switch is designed to have different contacts engaged at different points when it's turned; so tail is engaged when the key is turned to P, and still engaged when it's turned to "On."
  11. waldo
    waldo Member
    San Jose, Ca. 95125
    I see what you are saying, I NEVER would have seen it had you not directly pointed it out. I stand corrected, Thank you sir
  12. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    How hard do you think this loom would be to wire up? I need to get rid of the spaghetti monster under my seat.
  13. timbojim
    timbojim Member
    Kelowna, BC, Canada
    Well thank you for the new diagram. I wil be sure to add the signals to my existing one.
  14. dwcopple
    bay city, michigan
    I've done it in twenty minutes...
