High RPM's
Discussion in 'XJ Technical Chat' started by RSpark, Jan 22, 2012.
  1. RSpark
    RSpark Member
    Dubuque, IA 52001
    Is there a way to lower the RPMs of my '82 550 maxim? I was thinking maybe changing the front sprocket but was unsure if it was ok to do? I plan on riding from to Dubuque Iowa to my Hometown in Billings MT this summer and almost the entire route is I 90 at 85 MPH. My concern is that the rpms at 60 run around 6 grand. Any Thoughts?
  2. bigfitz52
    You could go up a tooth on the front sprocket if you want; they're available.
    But if you're worried about running the motor at 7K all day, don't be. You won't hurt it, provided it's in a proper state of tune. I run 80 for extended periods during my commute and the motor doesn't even break a sweat.
    MY "thought" would be: why the heck would you take the freeway for a trip like that? I'd be on the "2-lane blacktop" myself rather than the superslab with all those trucks.
  3. Bushy
    Bushy Active Member
    Yeah me too fitz, 2 lane black top and a bit of dirt road..
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I agree. There would be a lot of nice scenery on that ride.
  5. hogfiddles
    No reason to do that........you can run higher rpms all day long on a 95 degree day and the bike won't even start to break a sweat.
    Dave F
  6. RSpark
    RSpark Member
    Dubuque, IA 52001
    I have to take I90 in order to get as much time visiting friends and family because even going that route it's a 17 hour drive straight through. I will bump it up a gear definitely. Just for my own piece of mind, because it gets nasty hot out there especially in July and August.
  7. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    You could also change the rear to further increase your rpm/speed ratio. If you are going the interstate route I would look into a manual cruise control for your throttle, and some kind of windscreen if you don't have one already. Make sure your bikes in good tune and take some emergency stuff with ya. (fresh plugs, extra cables, fuses, water (for yourself), etc.)
    I can make almost as good of time on state highways as I can on interstate just by going a little bit faster when the highway opens up and there is little traffic, which on you're route would be often.
  8. RSpark
    RSpark Member
    Dubuque, IA 52001
    I plan on having a good emergency kit put together including oil, oil filter, plugs, first aid kit, clutch brake cables, a full complement of extra fuses and $1,000.00 petty cash just in case shit happens.
    I want to ride I90 also because That's the route I took when I rode from Montana to Dubuque on my Honda CB 360T..... Besides there are some good coffee / food stops on that route.
    Are there any adverse affects to changing the sprockets I should be aware of?
  9. tskaz
    tskaz Active Member
    Only if you don't torque the bolts to spec.
    The chain should also be replaced when replacing the sprockets.
  10. iwingameover
    iwingameover Active Member
    cramp buster. Best $12 I ever spent on the bike.
  11. RSpark
    RSpark Member
    Dubuque, IA 52001
    Where do i find that for 12?
  12. iwingameover
  13. RSpark
    RSpark Member
    Dubuque, IA 52001
    Nice I'm definitely picking one up
