hole in frame
Discussion in 'XJ Technical Chat' started by ant797, Apr 18, 2016.
  1. ant797
    ant797 Member
    western australia
    i noticed a hole in the frame hovering around the neutral safety switch area its the size of the end of my pinky and end and tapers off to a crease about a cm i was wondering if this is purpasely done as a crumple zone or just something i need to get welded
  2. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Maybe someone notched it to get to the neutral safety switch , get it fixed properly, or the frame will wobble till it fails..... Not good
    Alan
  3. Yardawg
    Yardawg Active Member
    Hatch NM
    I noticed small holes on my frame in the exact same spot. Guess I need to get that fixed soon too
  4. TheCrazyGnat
    Central PA
    I believe there is a hole in the frame there to facilitate drainage of any liquid that makes is way into the frame, but I'm not entirely sure. I think this was brought up in a previous thread about something else.
    Yardawg likes this.
  5. k-moe
    That is a common area for the XJ frame to rust. A proper repair is to cut out a section of frame tube back past the rusted area(s) and sleeve weld in a new section. If the holes are small (less than 1/4 the diameter of the tubing is the guideline I use)they can be welded or brazed shut after cleaning them back to unrusted steel.
    Alternatively the rust can be cut put, and a scab welded over the effected area. That is an ugly repair, but done correctly it is nearly as strong as a sleeve repair and takes much less time.
    Yardawg likes this.
  6. k-moe
  7. mlew
    mlew Well-Known Member
    Apex, NC
    There are drain holes in the frame but they are small, about 1/8 ". If you have a pinky size hole something is wrong.
    Post a pic so we can see.
  8. TheCrazyGnat
    Central PA
    Yes,I missed the pinkie size part; unless you have incredibly small fingers, I'd post a pic.
  9. Yardawg
    Hatch NM
    Cool. I guess mine is just a drain hole then
  10. k-moe
    I don't know about your pinkie, but mine is 1/2" across at the fingertip. That is four times the size of the drain holes.
    Photos please.
  11. ant797
    ant797 Member
    western australia
    i guess it was a drain hole that rusted out
  12. k-moe
    If the photo is oriented the way I think it is, that isn't a drain hole. The drain holes are on the very bottom of the tubing.
    Take an awl and probe around the edge of the hole. Get a feel for how thin the steel is there.
  13. ant797
    ant797 Member
    western australia
    the photo is a bit blurry but uou can see where it sort of tapers off to a crease i think it may have been welded before
  14. jayrodoh
    jayrodoh YimYam
    Cleveland
    I had rust in the same spot. Luckily my bike was torn down so a quick trip to the welder and a couple six packs, he was able to patch it all up. He did find a couple other spots and fixed/sectioned as needed.
    You don't want your bike coming apart there at 65 MPH :eek:
  15. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    It was the same with mine, had to cut it and weld in new peaces about 4 inches on each side. It was rust after sitting outside for 10-15 years, probably got filld with water.... Not sure how much it would affect handling if it broke, think the engine should keep it together anyway.
  16. saftie
    New York, NY
    Not sure if anyone ever wants to find out
    jayrodoh and Big swede like this.
  17. mlew
    Apex, NC
    That's looks more like a rust hole that a drain. A drain will be directly on the bottom of the frame, that hole looks to be at the 8 o clock position. I also see cracks coming out from the edges.
  18. k-moe
    Think about how a hinge works.
    The engine is not a stressed member, so it contributes very little to overall chassis stiffness.
    The Maxim engines are rubber mounted, which makes things even less secure after a lower cradle failure. Handling will be affected negatively. It won't fall apart right away, but eventually there will be additional failures as the engine mounting points flex and stress-cracks develop. Before that the back end will feel "wiggly." Wiggly is very not good.
    Alan63 and TheCrazyGnat like this.
