horn and start button
Discussion in 'XJ Technical Chat' started by Deathmetaldan, Jun 3, 2008.
  1. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    hi guys, i just bought a 79 xj1100 special. Somehow the horn button and start button are missing. Should i get all new controls or can i replace the button? Also, it starts really hard. There is no air filter in it so i think that might be why. It spits and sputters and stalls until it has run for quite a long time, any ideas?
  2. leadboots
    leadboots Member
    aylmer ontario canada
    do you know how long it sat for. If its a longer time you may wanna clean the carbs out?
  3. Deathmetaldan
    Sunbury PA 17801
    the guy said he cleaned/rebuilt the carbs, and put in a new battery, plugs and oil
  4. leadboots
    leadboots Member
    id still pull them and give them at lookin at. Some peoples carb cleaning is not the greatest.
  5. Deathmetaldan
    Sunbury PA 17801
    anybody have any idea about the buttons? starting the bike with a screwdriver is getting really old really fast
  6. TIMEtoRIDE
    Until you get the right buttons installed, new or used, you can rig up a cheap horn button from an auto parts store to the 2 wire pigtail on the solenoid. Red/White gets fused 12 V power, the other wire drops to ground thru the button.
    Bike junk yards won't break-up a good control cluster, but might just give you a damaged cluster (road rash) that they can't otherwise sell.
  7. weoxstan
    weoxstan Member
    Central Michigan
    I think i read in the long chacal post that he has them. A little longer then stock but still look really good.
  8. Robert
    Chacal has replacement buttons and I vagely recall Injeneer has them as well. I'd pull the carbs even if the fellow said he cleaned them. Lead boots is right, some folks don't know what they are doing and will call a rinse "cleaning" the carbs.
  9. Deathmetaldan
    Sunbury PA 17801
    is there anyway to clean them without taking them off the bike or taking them out of sync?
  10. Robert
    Nope, gotta pull 'em. Bite the bullet and dig in.
