Horn connections?
Discussion in 'XJ Technical Chat' started by digitaldrifter, Aug 12, 2016.
  1. digitaldrifter
    digitaldrifter New Member
    Bloomington, IN
    I've noticed that my 1982 XJ750 doesn't have horns anymore. I see a bunch on e-bay, but I'm not sure exactly where they plug in to. I don't see a spot in the rats nest behind the headlight, but I do see a couple of free connectors under the tank above the cam cover. Any suggestions?
    There are two spade connectors for the horns, one each side.
  3. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    I just happened to have a picture of mine, since I had to remove them when doing my valve clearances, to get the cover off. Maybe it will help.
  4. digitaldrifter
    Bloomington, IN
    Interesting. It looks like I have provisions for two horns on each side, one each under the handlebars. I do have two disconnected spade connectors under the tank above the valve cover. I'm going to go through the Haynes manual again to see if it has the color codes for the wires in there. Thanks for the tips so far.
  5. Jetfixer
    If it is a seca it is accessed by removing headlight .
  6. k-moe
    Same for the Maxim 750.
  7. digitaldrifter
    Bloomington, IN
    Great, thanks for the heads up. I'd like to be able to honk. My middle finger isn't that loud. :p
    TheCrazyGnat likes this.
  8. chacal
    The only pink wire on the bike is for the horns..........
  9. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Maybe you should turn it up.
    digitaldrifter and TheCrazyGnat like this.
  10. digitaldrifter
    Bloomington, IN
    I would use both of them, but I'm still a new rider.
  11. Polock
    if you want to be a old rider, never piss off a 3000 lb automobile with a 500 lb motorcycle, the numbers just don't work
    Lightcs1776, k-moe and chacal like this.
  12. chacal
    Another fine example of the kind of sage advice and superior wisdom that can ONLY be found at xjbikes.com !!
