how much $$
Discussion in 'XJ Modifications' started by cg82, Jun 27, 2014.
  1. cg82
    cg82 Member
    Rossland British Columbia
    hey Guys,
    Just curious, for you guys that have completely restored or rebuilt your bikes, how much cash are you into it for? counting purchase price.
  2. bigfitz52
    Generally speaking, the budget for a proper recommissioning runs between $600 ~$800 regardless of purchase price. This assumes all DIY labor and little or no cosmetics (like paint.)
    It's easy to spend quite a bit more; but you generally won't get away for less.
  3. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    How far into the bike are you talking about? I am in the process of pricing up the entire engine rebuild, and $6-800 will just cover the cost of that from crank to carbs, with my hands providing the labor. Then it's probably the half again as much for a full suspension/tires/brakes and bearings overhaul. Then its paint on top of all that, and that assumes the electrical are all in good nick.
    Why are you budgeting for a full engine rebuild? Are you certain that it needs one?
  5. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    $500 for bike $2500 in customization is an conservative understatement of the parts. Labor, I cant even imagine how much it would be if I didnt do the work
  6. Bigshankhank
    Bastrop, TX
    This engine was full of water, so all seals, gaskets, bearings are being replaced. In addition, the cylinder walls and cams are pitted to the point of being useless, so I bought a good condition replacement top end already. There is no way to make resleeving all four cylinders economically feasible.
  7. ingie1062005
    ingie1062005 New Member
    Armstrong B.C. Canada
    In Canada the cost is a little higher, I stopped counting at $1200.00 this is just engine the only outsourced labor was boring the cylinders $485.00 from stock to Big Bore kit (65 to 68mm) Grade 8 flanged bolts and Bearing shells from Yamaha are expensive! The piece of mind is worth every penny.
  8. hogfiddles
    I don't keep track of $ or time. I just have fun working on them when/as I can.
    Dave
    Hotcakesman likes this.
  9. k-moe
    OK. I forgot about your post on that.
  10. cg82
    cg82 Member
    Yeah, i am not wondering for any particular reason, I was just wondering if you guys dump as much money into it as I do and what those of you with bikes that are done being restored (for the most part) have spent.
  11. cg82
    cg82 Member
    bump! for you guys that stripped everything, painted frame, replaces all rings and gaskets and rusted bolts, what do you think you spent? $2000, $5000?
  12. Onetrackstu
    Onetrackstu Member
    Delray Beach, FL
    Better part of or near 4k. It's full custom from the ground up so I spend money on it when I can
  13. Polock
    a basket case with title and a spare whole bike without title for 500 then
    fork seals...................25
    progressive fork springs.....80
    gators.......................15
    headlight....................75
    speedo/tach..................90
    gasket set..................100
    spark plugs..................12
    dyna coils...................60
    paint.......................220
    super trapp muffler.........100
    turn signals.................30
    grips........................15
    bars.........................40
    mirrors......................30
    clutch.......................??
    electrics....................20
    trans gears................?50
    tires......................150
    led light...................40
    brakes/ss lines............100
    valve shims.................20
    ss nuts/bolts...............40
    progressive shocks..........85
    about.....................1350
    steering head bearings
    this is all from memory, what's left of it, so not exact but it's close
  14. k-moe
    A lot of the cost will be determined on how much labor you provide, and how much you have to farm out. I can do a decent paint job for a daily-rider, but i'll have a professional do the paint if it's a true restoration and the paint isn't in great-original condition.
  15. trgrhappy
    trgrhappy Member
    Post Falls ID
    Lets see here..... $30 for the bike, about $2-300 getting it up and running right, then I began the bob. $500 or so in pieces and parts (seat, lights, tank, front end, wheels, etc.) spent the winter 2 years ago working off the barter for custom paint and body work. ($2000+ value), and conservatively 600 hours of "therapy" (labor).
    The first pic is the day I picked her up
  16. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I spent around 800 the last spring, and this spring I am putting another 300 or so into my
    bike
    I did the important stuff last year
    and I am doing more tweaks this year
    are you ever done? and can you put a price on fun?
