How reasonable to remove/reinstall exhaust assembled?
Discussion in 'XJ Technical Chat' started by Metal_Bob, May 20, 2012.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    I have header gaskets and a parts bike.
    Other than wanting a helper, how difficult would it be to wiggle on 4 headers, install collector mounting bolt and get mufflers nearly lined up WITHOUT taking off all pipes seperately (and replacing ALL of the gasket$$)
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    not that bad as long as you have 2 people to do it. I have done it on a couple bikes.
  3. bigfitz52
    Fist off, as long as they're not damaged, the pipe-to-collector gaskets should be OK; you'll want to loosen those clamps so the pipes can move about a bit.
    It's much easier if you can pull the mufflers; and then get a helper.
  4. Metal_Bob
    Bourbonnais, IL
    My "running" bike's left muffler is JAMMED on and I can see warped gasket material sticking out. I may get it off, but no luck yet.
    Other than some blue-ing parts bike exhaust system looks way better over all. I can try to loosen those mufflers when I get a chance.
  5. Metal_Bob
    Bourbonnais, IL
    Aero KROIL
    is either the best thing EVER or I'm extremely lucky!
    I just loosened 16 header bolts (2 bikes) with VERY minimal effort (and 1 hammer tap on the rustiest of them).
    Granted I did liberally spray them 2 or 3 nights ago, but I was quite shocked and amazed!
  6. Billt1969
    Billt1969 New Member
    Erie Pa.
    Aero Kroil is the best thing ever!
