how to remove broken exhaust studs?
Discussion in 'XJ Technical Chat' started by RicXJ750M, Jan 15, 2006.
  1. RicXJ750M
    RicXJ750M New Member
    Crawford, GA
    Re: Headlight and Exhaust Options
    I recently acquired an '83 Midnight Maxim (750) and the exhaust is trash. There are 3 exhaust studs broken off and the rest are suspect. Anyone had to deal with these? They are so small in diameter I'm wondering of I can drill them and get an EZ-Out in it. I bought some more headers and will be redoing the entire exhaust and want to get rid of the collector box since it is toast, too. Spinalator has given me some ideas.
  2. Hillsy
    Hillsy Member
    Hi RicXJ750M,
    Broken exhaust studs are notoriously hard to remove. EZ-Outs will more than likely snap off in the hole - which means you will now have a hardened steel plug in the bolt to try and remove....
    If there's enough of the stud left, try giving it a good hit with a suitable punch and hammer, than grab it with vise grips and try to undo. Failing that, you can try heating the stud with Oxy. The stud will glow red before the aluminium on the head and this can be done with the head on the bike. After it cools it should be easier to turn.
    Otherwise, you might have to take the head off and get a machinist shop to drill out / helicoil the threads.
    Once you get them all out, use an anti-seizing thread treatment on your new studs to make sure they won't break off again.
  3. SnoSheriff
    MB, CAN
    moving to appropriate forum and split into its own thread/topic...
    Welcome to XJBikes :D
  4. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    You could try these...
    Irwin Bolt Extractors
    I have a set, but haven't used them yet. They were not terribly expensive, and do not require drilling, or pose the risk of snapping off in a hole. Others have sworn by them. I was planning to use them to get the rusty allen bolts out of my turbo housing when the left side muffler finally becomes unusable.
  5. dinoracer
    dinoracer Member
    Chattanooga, TN
    If you go the route of having a machinist machine the busted studs out, go ahead and go up one mm in dia from a 4 mm stud to a 5 mm stud. Then they will not break as easily
    Sean
  6. RicXJ750M
    Crawford, GA
    Thanks for the info...will check into those Irwin Bolt Extractors. Will post how I come out.
  7. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    DO NOT! I REPEAT -- DO NOT!!! TRY TO USE ANY SORT OF EXTRACTOR ON THESE BOLTS!!! IT WILL BREAK OFF!!
    I can inform you from EXPENSIVE experience that it is NOT worth it to even try! I had several of the intake bolts snap off when I replaced the carb intake boots. I attempted to use an extractor, but broke it off. I then brought it to a machine shop, where I was quoted $175 to drill and Helicoil the 5 holes, PLUS $100 to have the extractor burned out with a laser.
    The problem is the bolts/studs are very small, so the extractor is going to be even smaller. The bolts/studs are fused to the head by galvanic oxidation, which is like Krazy glue. It does not let go.
    Also, be sure to budget about $125 for the top-end gasket set (valve cover, head, and timing chain tunnel), because the old ones can not be reused after you take the head off.
    -Matt
  8. pianomangg
    pianomangg New Member
    Calgary, Alberta
    I sympathize, Taz. Had three of those intake bolts snap off on my Seca. Pushed it down the block to an independent auto garage. After extracting what was left of the three bolts and installing one helicoil, I had to leave $177 behind :p
    It's one of those nasty things about owning old bikes... can't do much about it if it happens, just breath deeply and reach even deeper into your wallet.
    GG
  9. RicXJ750M
    Crawford, GA
    OK..tis expensive to get a shop to take them out. Anyone tried drilling and tapping them at home?
  10. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    If you look at the pictures of the extractors in question, you will notice that they do not require drilling like an Easy-Out (an oxymoron if ever there was one). They have a left hand spiral flute that goes over the remnants of the bolt in question, and turns them out like a regular bolt head. The worst that can happen is that the bolt rounds off, or snaps off at the head, at which point, you are no worse off than when you started. Ideally, I'd like to be able to pass a high current electrical load through a bolt and heat it up before I try to break it free.
  11. RicXJ750M
    Crawford, GA
    Got the message in the first post...My question was: Has anyone tried drilling (not for an extractor) the bolt out and re-tapping the hole themselves and not taking it to a shop? Seems to me, if you use a carbide bit or better, the broken off stud can be drilled out, possibly drilled to a larger size and then tapped for metric or standard threads. Any thoughts?
  12. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Actually, I was trying to quote the other post, sorry. Drilling the hole out is a hit or miss affair. I have done it many times at work with mixed results. You need a very sharp bit, preferably a cobalt or carbide bit, and very good aim to keep it from wandering to one side. One other thing I didn't suggest was to use left handed drill bits to remove the stud. You can get them fairly easily from a good machine shop supplier. On another board I visit, dedicated to restoring old machinery, they swear by them. They often have to get out broken studs from machinery that has been lying fallow out in the elements for decades at a time. The trick is that as the bolt gets thinner and thinner, it gets easier to turn (with the help of lots of penetrating oil of course, which can be applied down through the hole). The counterclockwise motion of the drill bit tends to walk out the broken bolt on its own once it gets thin enough.
  13. capy
    capy Member
    Florida
    If you are going to try to drill and tap them out yourself, you should try to fabricate yourself a guide. You want to make it sit on the hole at the same angle as the bolt you are trying to drill out and measure the depth to wich you need to drill into the head.. the guide should be small enough to hold your drill bit firmly and possibly bolt on to allow a solid foundation....Any local machine shop can build one for you if you are unsure of your own abilities. Without it, you will more than likely drill into the good material and prevent a helicoil from having the proper strength.
  14. RicXJ750M
    Crawford, GA
    Thanks for the suggestions...will keep my progress posted in case someone else has the same problem and doesn't want to spend big bucks to fix it.
  15. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    My apologies.. I didnt bother to check the link for those Irwin extractors.. I've seen those at Home Depot, and they do look somewhat useful.. However, if the bolt snapped off flush (like mine did), they wouldnt do much good.. ;)
    If you're going to attempt to drill them yourself, I have some suggestions..
    - Use a drill press. Don't attempt to use a hand drill. If you are going to try left-handed bits, you need to use a reversable drill press.
    - Make sure the press table is tightly secured and perfectly level on all angles.
    - Make sure the bit is perfectly centered on the bolt to be drilled. If it is offset, the spacing won't match the flanges.
    - Clamp the head onto the table, making sure IT is perfectly level.
    - DO NOT GO TOO DEEP! I believe the holes are 3/8" deep. Use the depth stop on the press - that's what it's for.
    - You will need a bottoming tap to finish off the threads in the hole. The tap that comes in the basic kit is a standard tapered tap, which will not cut threads into the bottom third of the hole. You will need this whether you are using Helicoils or direct threads.
    Good luck
    Matt
  16. Brian750R
    Brian750R Member
    Boston MA
    i know it might be a little late, but just as general knowledge, a trick i learned while in an engines class at my school, is that to remove a stuck bolt, you can use a torch to heat the bolt and the surrounding thread, then using a special material (i cant remember what it was called, and will try to look it up int eh book when i get home) you cool the bolt. then since the thread is hot and the bolt is cool there is more clearance allowing for the bolt to turn freely.
  17. stevesearles
    stevesearles New Member
    Just snapped off an intake manifold bolt myself last night. I am sick about it. There is no way heating and cooling helps because of the chemical action between the two disimiliar metals. I will sell this 1982 Yamaha Maxim XJ750 with 22,000 miles on it to anyone who wants to tackle this job for $500 cash. Pick up in Marshall, MI just off I-94. Call Steve @ 269-781-7788 or email: stevesearles@hotmail.com I have too many other projects to tackle this one. My loss is your gain!
  18. RicXJ750M
    Crawford, GA
    UPDATE: Just received some titanium left-hand drill bits. Will be trying those--don't want to break an extractor of in the bolt.
  19. Robert
    I don't know about you folks but I have broken off taps and easy-outs in blocks before and the safest way I know of to remove this nightmare it to suck it up and go have the bloody thing TIG'ed out. The heat from the gun helps loosen it up and the results are excelent too. No errant holes to have to deal with. Small price to pay when you need all the metal on the head you can keep. Fella just TIG's a small piece of steel to the ruddy stud and out it comes (usually with the force of your hand). After the stud is removed, replace it and don't forget the antiseeze or you'll be right back where you started in a few years. Good luck.
  20. RicXJ750M
    Crawford, GA
    Been awhile, but here's an update on my broken exhaust studs. After I had all the pieces/parts, I was wanting to get the job finished and forgot to take pictures. Bought some titanium left-hand drill bits off eBay. Made sure all broken bolts flush with head by using cut-off wheel in a dremel. Center punched the broken studs. Could not locate the right size metric helicolils, so drilled out old studs with 15/64 left-hand bit. Then drilled 3/8" deep holes with 17/64 standard HSS bit. Tapped holes with 1/4-20 bottom tap. Installed 1/4-20 helicoils. Installed headers and exhaust gaskets (got from eBay) using 1/4-20 stainless hex-head bolts and plenty of antisieze compound. Took about 1.5 hours from start to finish. Did not use a guide or jig, just made sure I drilled at the same angle as the good studs. Have to make sure you watch the angle when drilling those closest to the frame--the bit just about touches the frame tube. Now all I have to do is figure out what I want from the headers back. Anyone have any suggestions?
  21. DodgeitRamit
    DodgeitRamit Member
    Michigan
    Just an idea, don't know if it would work, but if theres a lil bit of the stud sticking out couldn't you weld a nut onto the stud, and of course soak in penetrating oil, and a lil heat and get them out? Or would that not work? Not very familiar with the aluminum heads and all but I was thinking about trying it
  22. MiCarl
    After purchasing my bike I replaced a broke exhaust collar stud and replaced carb holders without snapping a single screw.
    I cannot stress enough how easy these are if some heat is applied to the bosses the screws and studs thread into.
    I used an oxygen-acetelyne torch with a #3 tip dialed to the absolute smallest flame I could get. Plenty of oxygen so there is no orange flame at all.
    I used the same technique to extract the remains of a starter mounting bolt that snapped off.
  23. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I haven't had a broken exhaust stud in years. I did have one break off in the past and ended up just using that black woodstove glue to seal it just using one header bolt to hold the header pipe on and it worked. I figured the exhaust gets about as hot as my woodstove, so it should work. The stack temp reaches anywhere from 250 to 700 degress at times and I don't think engine header pipe gets much higher than that.
    I am not recommending this method however, just an option if your in a hurry to get out and ride.
  24. RickCoMatic
    Remove the cylinder head for servicing by an experienced machinist with the proper tools if you don't feel comfortable trying heating that stud.
    Just so everybody knows, for sure ... this situation, a broken-off exhaust stud, is the Undisputed Heavyweight Champion of Misery for XJ Bike Owners.
    Number One.
    People will say not to worry; it's OK 'cause it's not your fault and everybody still loves you.
  25. Flooglebinder
    Flooglebinder Member
    Brush Prairie, WA
    Glad you edited your post, Rick...I was just about to call you on it. :wink:
  26. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I agree with Rick Co, this is one of those 8 on a scale of 1-10 for hardness.
    The whole welding thing is for someone better than me.
    I have drilled out broken studs with lefthanded bits and had good success.
    I would recomend heating the head and soaking the broken stud with Aerokroil a penatrant oil. (hard to come by) then heat the head again once the stud has cooled and been flattened and centerpunched then start drilling.
    DONT FORGET to drill in reverse with a lefthanded drill bit or you'll ruin it right off.
  27. Gearhead76
    Gearhead76 Member
    Appleton WI
    you have to make sure to heat the bolt and not the aluminum head. alluminum will melt faster then the metal bolt. I've had good luck with heating the bolt and cooling it off with pb blaster penatrating oil it's worked for me.
  28. MiCarl
    I've been heating the aluminum, idea is to expand the aluminum away from the bolt/stud. You're heating both (via the bolt/stud) and then quenching the steel - shrinking it away from the aluminum. Definitely a safer way to go.
    Heating aluminum is very tricky, it shows very little color change going from cold/solid to molten (and is hidden by the layer of oxidization to boot).
    I've found though that with the tip/flame combination I mentioned before the aluminum doesn't get that hot. I'll admit though, my sphyncter was clenched tight the first couple times I did it.
  29. Gearhead76
    Gearhead76 Member
    Appleton WI
    As long as it works that's all that matters, just use what your use to probably the safest, I know some people drill out the bolts untill there right to the treads and then use a small chissle to chip away the thin amount left, Me personally I can't drill straight enough to do this, This would work for me if I used a jig I guess, but a guy at work does it all the time free hand, it's pretty amazing.
    But to each his own I guess
  30. chacal
    At a local electronics shop I noticed they had a spray can of fluid (gas?) that was labeled Freezing Spray......something for electronic circuit repair. I was in a hurry so I didn't study it (will next time) but I'm thinking it must be like that stuff they spray on an injury to "freeze" it and take the pain and swelling away......
    I wonder if a shot of that to the stud, combined with some heat to the surrounding head material---and of course the penetrating oil----might be a great way to go?
  31. MiCarl
    I believe the stuff you are referring to is component cooler. Used to check for electronic components that fail at higher temp (spray it on and things start working again). Not sure this would be cool enough to help much.
    I do like your idea though. Imagine heating that bolt cherry red and then hitting it with liquid nitrogen. Bet it'd practically jump out.
  32. RickCoMatic
    If you guy's are really going to do that ... could you, like ... hook-up for, like, a live webcam or have, like somebody gettin' like some good video of it man?
    Either the stud gets extracted and we'll all able to do it like in the video,
    or ...
    You'll have a tape to send-in for a shot at the Grand Prize on America's Funniest Home Video's.
  33. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Palying with quick frezzing is some what harmfull, and harmfull to your self. Being in a kitchen all day you see people do dumb things and one of thoughs things are throwing ice cold water on hot steel flat top. Crack split and a lot of steam, 2dn degree burns. So i think that if you extream hot and cold togeather you may get really bad results.
    But would love to see the vid of some one trying it
  34. RickCoMatic
    If you apply heat to the broken-off exhaust side stud, get it cherry red and hit the head with a freezing spray ... you could cause fractures to the combustion chamber.
    The steel Valve Seats will heat-up along with the aluminum.
    They won't cool down nearly as fast.
    If the aluminum is rapidly cooled, (spray-bottle water, cold-ragged, garden-hosed, freezing sprays, what-have-you) ... you run the risk that the narrow bridge of CAST aluminum, between the Valve Seats will hairline fracture.
    That's all she wrote.
  35. Hvnbnd
    St. Johns, Arizona
    Yep, that whole cryogenic thing is trouble just waiting to happen!
    ANYONE COMINIG ALONG LATER
    Please dont do this stuff!
    We're just talking and tossing stuff around and thinking.....what if?
  36. PainterD
    I am about to change the exhaust on my XJ and already sprayed the bolts with penetrating oil and let it sit over night. My plan is to hit the bolts with a hammer first, then remove the nuts. It worked on the bike I took the exhaust off of yesterday, so I hope it works for mine.
    I've heard of removing the nuts after running the bike first and getting the bolts/nuts good and hot. Makes sense to me. >PD<
  37. Danilo
    Danilo Member
    Vancouver canada
    Just had to replace 2 frozen exhaust studs.. At least I was careful enough .. this time :) not to snap the rascals off.
    Heating them Hot (almost red) with an Oxy torch .. THEN applying Parafin (candle wax) to the stud where it screws into the head ..repeatedly. then letting it cool.
    This allowed the studs to be unscrewed.. rather easily actually.
    I was told about this technique.. and Damned .. to my surprise it actually works. Has done so on many engines since.. be patient though this is no time for anger or hurry.
    Story is the hot metal wicks the wax in and it lubricates the threads.. where Liquid wrench had no effect whatsoever.
    Try it.. it works for me
  38. Alive
    Alive Active Member
    Queensland, Australia
    I Just broke off 3 (I repeat 3) intake bolts tonight on my 650 :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
    Don't have a gas torch and after reading this thread am feeling a little put off with the prospect of getting them out.
    Will put some oil on them, let em sit give them a knock and see if I can't pop the suckers out.... Failing that... Off to the bike shop it goes :cry:
  39. chacal
    See, everyone is using this new-fangled freezing method to get their broken studs out.......
    Ha-ha.
    What I was actually thinking----theoretically only----was that if you were
    able to "freeze" or just cool down ONLY the steel stud with a freezing spray, and then gently, SLIGHTLY warmed the head around it (at a pretty good distance, lets say 2-3" away fron the stud, and all around), the combination of the SLIGHTLY expanded aluminum and the as-much-as-possibly-cooled steel might create just enough additional clearance to allow the stud to be broken loose.
    In case I ever attempt it, I'll make a video for you guys.
  40. MiCarl
    Steel and aluminum is almost the perfect recipe for siezing. And I think Yamaha used the mildest steel they could get their hands on.
    I'm slathering eveything up with anti-sieze.
    I just might loosen and retighten those exhaust studs and intake screws anually too.
