hsc 32 carbs run fine , wont idle
Discussion in 'XJ Technical Chat' started by yamahaha, May 31, 2016.
  1. yamahaha
    yamahaha Member
    Have 81 xj 750 with 32mm hitachis. Bike runs fine once on main jet but will not idle nor start even when enriched. The bike will fire with a shot of carb cleaner in the airbox.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    When is the last time carbs were rebuilt?
    A good cleaning, replacement of worn components and proper synching will make you happy.
  3. yamahaha
    yamahaha Member
    Hydroblasted last week new needles seat valves all the bs. Just wont idle. ???
  4. Jetfixer
    Was the carb rack split ? Were the butterfly shaft seals replaced with the correct seals? Were the carbs bench synched? If the pilot jets are plugged this can cause problems, were the float bowls enrichment jet cleaned with wire? These are a few items that come to mind to check .
    yamahaha likes this.
  5. k-moe
    Not idling means that the pilot circuits are still dirty. Enrichment not helping means that the enrichment circuits are still dirty. These carbs really need to be cleaned by hand.
  6. yamahaha
    yamahaha Member
    Thanks for your help men, cleaned her all up and now she runs like a dream
