HSC32 Carb Question
Discussion in 'XJ Technical Chat' started by dzjenky, May 1, 2014.
  1. dzjenky
    dzjenky New Member
    CR, IA
    Okay, after cleaning my carbs and replacing my throttle shaft seals, I'm at the daunting task of putting them back together, which I'm pretty sure I've done correctly, except for one extremely confusing and frustrating part. I have one leftover lock washer.
    It's the little one in the photos. http://imgur.com/a/1ZtIK
    I'm pretty sure it came from carb #2, but it could be carb #3 also. However, it doesn't seem to fit on anything and there only seems to be 1. There isn't anything else like it.
    Also, another question, how tight am I supposed to make those 12mm nuts? I can tighten them down so hard, that even I can't force the butterflies open. I tightened them as much as I could with the spring still being able to close the butterfly, but they seem kind of loose.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    the only single lock washer showing in the manual is the one fitted with the enrichment circuit bracket screw that goes into the cold start shaft.
  3. dzjenky
    dzjenky New Member
    CR, IA
    I don't really understand what you wrote. I'm not most technically skilled person when it comes to working on bikes.
    It sounds like I'm on the wrong track about where it goes and that it's not part of the carburetor.
    However, I don't know what the enrichment circuit bracket is or the cold start shaft.
  4. rocs82650
    Middle Tennessee
    do you have a manual? it might be easier for me to tell you where in the manual I'm getting this information.
  5. schmuckaholic
    California
    Have a look at this file and see if anything there gives you an idea.
    Replacing the Hitachi throttle shaft seals
  6. dzjenky
    dzjenky New Member
    CR, IA
    Yeah, actually, that's the guide I've been using to do it.
    I don't have a manual, do you know were I could find one?
  7. chacal
    HCP2185 OEM throttle shaft end bracket retaining nut LOCKWASHER, use 1 per shaft on both the #2 and the #3 carbs. Made from 18/8 stainless steel and has a bright finish.
  8. dzjenky
    dzjenky New Member
    CR, IA
    Hey Chacal, I already have lockwashers on the #2 and #3 carbs. This is a 3rd lockwasher that I'm not sure what it goes to.
    It was in the tray for parts in the #2 carb I think. However, it may have been in the #3 tray, but I'm thinking it was #2.
  9. RickCoMatic
    It's hard to tell:
    I think the larger one belongs with a Screw from the back-side of the rack. Holding the body to the brace.
    The small one is probably a Hat of Bowl lock washer.
