Hypoid Gear Oil for Drive Shaft 81 XJ650
Discussion in 'XJ Technical Chat' started by xj6504lyfe, Apr 28, 2020.
  1. xj6504lyfe
    xj6504lyfe Member
    Norwich ny
    So I was researching on this forum and found a thread where someone recommended regular ol gear oil 80w/90 for the drive shaft??
    Does it not have to be hypoid oil? The guy at autozone told me that they don't have hypoid oil and that id need to go to a small motor shop.
  2. Rasput
    Rasput Member
    Victory Mills NY
    Hypoid is reffering to the design of the gears. There are two types of gears ; hypoid, and spur. Im a mechanic and can tell you that even though rear differentials in cars have hypoid gears, unless if its limited split, they use either regular or synthetic gear oil. If you are looking in the manual it might be using the term hypoid gear oil in an obsolete way. I would say that you are probably safe with gear oil. Anyone please correct me if I'm wrong.
    Franz, xj6504lyfe and Toomanybikes like this.
  3. Toomanybikes
    Tsawwassen bc
    image.jpg 39F70FBB-CA50-4328-8900-8041EC416061.jpeg Guy at autozone is incorrect. I have serviced dozens of shaft drive bikes. This goes in every one.
    Franz and xj6504lyfe like this.
  4. xj6504lyfe
    xj6504lyfe Member
    Norwich ny
    Wouldn't be the first time guy at auto one had limited knowledge, thankz!
