I have a 82' XJ650 Maxim...
Discussion in 'XJ Modifications' started by WesleyJN1975, Feb 22, 2007.
  1. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    ...and I was curious if you can put a larger gas tank on here without major modifications so that on long trips I don't have to stop as much for fuel? Thanks.
    Wesley
  2. CowboyBob
    CowboyBob Member
    Orange Co.,Virginia,USA
    I haven't done it; but from other letters on the forum, the xj750 tank is interchangeable.
  3. bosozoku
    bosozoku Member
    Albany, Oregon
    If you find one that fits and has significantly more room, you'll probably need to modify the front of your seat to fit the bigger tank.
    You might try a 650 or 750 Seca gas tank.
  4. Altus
    Altus Active Member
    London, Ontario
    More specifically - the 750 Maxim's tank is interchangeable - gives you an extra 6 litres of fuel (19 vs 13).
  5. chacal
    And the 750 SECA tank won't fit without a little bid of mods to the rear gas tank mount. And, it looks like butt. Without all those fairings, it just doesn't look right on a naked Maxim.......
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I had to edit this post because I changed my mind and decided to keep both tanks incase I need the extra fuel on longer runs.
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    That's cool. My buddy had an extra 750 maxin tank, we tried it and fit right on. Thanks for the help guys.
  8. gbuddyjoe
    gbuddyjoe Member
    New Hampshire
    So just so that i can make it clear for me anyways, do the posts above mean that you can mount a XJ750 tank on the XJ650? I have a '83 XJ650 and am hoping that i understand it correctly as I would love to be able to extend the range on my baby.
  9. Altus
    Altus Active Member
    London, Ontario
    That is correct - the XJ750 Maxim's tank will fit with no modifications on an XJ650 Maxim.
  10. gbuddyjoe
    gbuddyjoe Member
    New Hampshire
    Thats awesome...
  11. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    I have an xj750 tank on my 650 and it makes it look beefier and I get more gas per fill up which is great for those long rides.
  12. garofski
    garofski New Member
    Wales
    Will the XJ750 Tank fit on a my 550? I would love to extend the mileage for my baby? Th guy's i ride with sigh when i signal i need fuel :(
  13. FloridaBiker
    FloridaBiker Member
    Jacksonville, FL
    I once put on a Honda 750 tank (1982 750 K or C) - NOT SURE)
    very little mods.
    If I remember correctly, the difference was in the hold down bolt and needing different rubber grommets at the front.
  14. Altus
    Altus Active Member
    London, Ontario
    As we discovered in a different thread - no, this is not a direct swap. The 550 uses a slightly different size tank than the 650/750's so the tanks don't fit.
    Sorry
  15. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I've got a 750 tank on my 650, it make s a huge difference, It looks beefier, and the extra 6L is great
  16. PainterD
    Garofski,
    To answer your question, NO, a 750 Seca or 650 Maxim tank will not fit on your 550. Just find Sanoke and ask him.
