i need help
Discussion in 'XJ Technical Chat' started by reichert35, Oct 27, 2008.
  1. reichert35
    reichert35 New Member
    missouri
    i just adjusted my cam chain tensioner following the service manual step by step and now my bike (82 XJ650RJ seca) wont start!!!
  2. bill
    bill Active Member
    Raleigh, NC
    Hi we need some details. Won't turn over, turns over but no spark, etc?
  3. reichert35
    missouri
    it turns over and all four plugs are sparking its acting like its not getting gas i sprayed starter fluid in the carb throats and still nothing.
  4. bigfitz52
    Sorry but I gotta ask: When you were adjusting the camchain, did you have the ignition cover off? If YES, were you careful turning the motor over by the end of the crank so the wrench DID NOT scrunch into the ignition pickups (and move them..?) If that answer is also yes, then the problem is almost certainly NOT related to adjusting the camchain, as long as you got the tensioner tightened back up correctly (manual tensioner only.) Did the adjustment procedure involve loosening a bolt and nut on the tensioner unit?
  5. reichert35
    missouri
    i dont think i touched the ignition pickups are they real easy to move how do i know if thats the problem? and yes i loosened the lock nut then the bolt and tightened them both back down
  6. bigfitz52
    No, the pickups aren't easy to move, you'd have had to mash into them pretty good to move 'em, and you'd know it. Just checking. Ok, good---did you use a torque wrench and/or go real easy on the bolt/locknut? If you followed the book (not hard at all) and did it all step by step, then you have a raw coincidence here, a simple camchain adjustment won't kill your bike. You said you have spark. Starting fluid isn't necessarily a good diagnostic aid. Put the petcock on PRI (don't leave it there forever) and let's see what happens.
  7. asphaltgecko
    asphaltgecko Member
    any gas in the tank ?
  8. baz666
    baz666 Member
    Washington, DC
    the cam chain adjustment's got nothing to do with starting the bike. It'll still start, unless as Bigfitz mentioned, you displaced ignition components. Don't think of it as a cam chain related issue. Sometimes bikes like to lead you in the wrong direction. Check the obvious stuff first. Is your engine kill switch on? Is the battery topped up? Is there gas, as asphaltgecko asked.
    Did you disconnect something else? Do you have a green neutral light when you've got the bike in neutral? Any fuses blown?
    Check the troubleshooting section of your Haynes manual. You have one, right?
  9. asphaltgecko
    asphaltgecko Member
    check the battery terminals for tightness... TODAY, MY 750 WOULD CRANK BUT NOT START, RAN DOWN THE BATTERY PRETTY QUICKLY, WENT TO JUMP IT, THE + TERMINAL SCREW WAS LOOSE, TIGHTENED IT,
    VAROOOOOOOM ! STARTED RIGHT UP......FUNNY THING, IT TURNED OVER AND OVER, LIKE IT WAS TRYING TO START, YOU WOULDNT HAVE SUSPECTED THE TERMINAL WAS LOOSE.
  10. reichert35
    missouri
    turns out it was the battery i charged it and it started right up. thanks for all the help
  11. bigfitz52
    I experienced the same thing...My '83 would SPIN right over, quite fast, but absolutely not start; was showing 8V on the dash gauge. Charged the battery fully and it fired right up, showing 12V when the key was switched on. I had always assumed if the battery were down far enough to affect starting it would be spinning slower. NOT the case.
  12. asphaltgecko
    asphaltgecko Member
    basics .. gas...electricity...air.... ingnition key... gotta have em...
  13. wizard
    it's all about distribution of power, the juice is going to the starter & starving the coils.
  14. bigfitz52
    Apparently. Never experienced that with a vehicle before, but this is my first real experience with electric-start bikes. Every CAR I ever dealt with would still fire even if cranking slowly.
