I need to get a grip!
Discussion in 'XJ Technical Chat' started by geebake, Apr 20, 2007.
  1. geebake
    geebake Member
    Audubon, NJ
    I need to replace the grips on my Turbo. Anything I should look out for? Are 'universal' grips truly universal? Do I need to get a pair that are a specific size?
    Anyone recommend and grips in particular?
    Thanks,
    Greg
  2. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I'm pretty sure any set of grips for 7/8 bars will work, they all just pretty much slide on
  3. Altus
    Altus Active Member
    London, Ontario
    Find a set you like, and get them for 7/8" bars.
    Getting the old ones off will probably be the hardest part.
    On mine when I had to remove the original stock grips, the throttle side pulled off with enough pressure and the help of 2 screwdrivers for some leverage.
    The other side however, I ended up having to cut off -- wouldn't move for nothing.
    Since then, the two sets I've been through have been great, and no issues getting off or on.
    Recommendations are tough - it's really a personal thing for looks and feel. I like simple, large diameter grips.
    I've done the foam grips, which weren't bad.
    Currently I've got these and am REALLY liking them:
    Embossed Rubber Grips
  4. Ease
    Ease Member
    NL, Canada
    I use progrips, SuperBK grips.
    Progrip.com
    You can get them at any motorcycle parts shop / dealer. Seem pretty good. More agressive for the style of bar I have on my seca.
