i want to punch an Electrical Engineer and baby in the face
Discussion in 'Hangout Lounge' started by schooter, Aug 18, 2010.
  1. schooter
    Ok, so I have a 2006 grand prix, I go to college 9 hours away, and i dont have cruise, i've gotten used to not usin it, but my dad was pushin me to get it fixed, blah blah blah, already put 300 into someone trying to figure out what was wrong, so it's been in the shop for 3 weeks, with all sorta of man hours, reprogramming, and a new body module, well, i dunno if you looked hard at a new grand prix, but the spoiler is just a hunk a plastic, i wanted something a little sportier, though not ricer, and my new spoiler's tail light is LED, well aparently the FRICKEN spoiler running light's resistance has some fricken thing to do with the brake sensor and the lower LED resistance made the compooper think the brakes were on, and the bill is going to be 1000 for that fricken goof up, I got an ear full from my old man, telling me that i just spent 1200 on a spoiler, there was no warning on the site, nor would something like that have even crossed my mind when putting it on, what if the running light burns out? will the cruise stop working? wouldnt some brake switch like on a motorcycle, somthing simple, that would cost $5 to replace work well enough to shut the damn cruise off?
    im going for mechanical engineering, but have lots of EE friends who im going to give a shot to the kidneys for this.
  2. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    schooter sorry for your bad luck but if it's any concillation my seca's atari reports that I have a blown tail light when I run the led bulbs in the rear :(
  3. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    That sounds like a bit of a bogus explanation to me.
    Reality is probably more like:
    Well sir, we worked on your car for MANY MANY hours and then it dawned on us to check the fuse and change it so now we had to make up this bogus description so you would cover our labor time.
    Similar story:
    My A/C became erratic in my car. Sometimes it would work OK for a while then not. (usually when it was hot as hell).
    Took it to a local shop and they checked system, vacuumed it down, checked for leaks, re-filled (charged me $220)...I didn't even make it home and it stopped. Took it back next week and they double checked and ran for 30 minutes. It was an ice-box inside.
    Got in and drove home. On the way to customer next day it stopped working WTF??
    It was at dealer for timing belt etc and they also worked on it. No issues they said but gladly took my $75 for A/C inspection. Three days later it stopped again. A couple calls and another inspection with leak test etc and no joy.
    Occasionally it would come on and then go off. It seemed related to bumps in the road. I searched and searched for a loose wire.
    Finally I sold it to a friend.
    When it was NOT working, the compressor clutch would not engage. We decided to simply install a toggle switch. In the process, it dawned on me after we tested "hot-wiring" it that the clutch on the compressor was controled with a relay.
    I opened the fuse-box/relay panel and "cool>>the fog light uses the same relay"
    Switched the two relays and BAM>> AC works fine now ALL the time.
    Damn $12 relay cost me hundreds of dollars and thousands of miles sweating and cursing.
  4. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    I can't stand the new electronics in cars today. I've been a tech for a long time and seen some really crazy things. The strangest so far was a lady comes in saying her car is losing power. Nothing is out of the ordinary, nothing, but the drivers window doesn't work. A few shorts in and fried circuits later and that was all the cause. A damn blown window motor caused a loss of power in the engine. Someone please tell me how cars these days are really getting better. Give me a manual tranny and a carbed 350 and I'm happy.
  5. MiCarl
    Re: i want to punch an Electrical Engineer and baby in the f
    It's not the electrical engineers, it's the lawyers.
    "Government Motors knew how to build a cruise control that would cut off when the brake lights were on but they didn't do it to save $0.02/car. Because of those greedy fat cats Mrs. Jones will never play the piano again." There goes $20 million.
    That's the same reason it takes three hands to start a push mower now. Need that bar because it's unreasonable to expect Mr. Jones to be smart enough to shut the mower off before reaching under it.
  6. schooter
    no, i checked the fuse, but the mechanic is a local guy, and kind of a distant family friend, he wouldnt do that, but he said in his wiring diagrams, there wasnt a resistor listed
  7. Raven
    Raven Member
    Twin Cities, MN
    Just so long as the PassLock in your ignition hasn't gone out yet...
  8. iwingameover
    iwingameover Active Member
    He's a mechanic. Most do it to some degree some worse than others.
  9. bigfitz52
    How about "schooter went and installed some cheesy accessory that screwed up his electrical system and confused the computer."
    I think that's probably a little closer to the reality...
  10. markie
    markie Member
    Suffolk, England
    Perhaps Schooter will be seduced by the dark side? (Electrical engineering).
    Modern car electrics are unreasonably complicated - all under the heading of "protecting the environment" and this probably puts a lot of fault diagnosis outside a regular garage, however I would seriously question being charged $1000 because you have fitted the wrong spoiler!!!
  11. mhajicek
    mhajicek New Member
    I'd say a lot if it is due to "design by committee" combined with "engineering by management".
  12. schooter
    2006 was the first year on the grand prix with the electronbic cruise and not alinkage type system.. mmm
    schooter did put a cheesy hunk of plastic on his car that messed up the cruise,
    though i think the way the system is designed, is like if you dont put on your gas cap, then your anti locks dont work because the computer couldnt detect the engine was running because the movent of the car didnt make any gas vapor from movement of the car, thus it would have been recorded by a pressure valve on the gas cap.
    if it aint broke dont fix it.
  13. Polock
    a distant friend that's getting real distant
    when you walked in this is what he saw
  14. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Fitz, you're such a dad :lol:
    And right on
  15. theadbrewer
    theadbrewer Member
    Roseville MN
    Cars are designed by engineers that don't know how to work on them if they had too. All wiring systems should be isolated from each other Duh but you have to take into account the accountants that want a $100 car not $105 car that kills the bottom line.
  16. schooter
    i just think it's dumb ho it's designed, the larger the system, the more chances for variables. a simple brake sensor would wok
  17. 1904xj
    1904xj Member
    San Diego CA
    I'll line up to get the next punch!!!
  18. xjdaver
    xjdaver Member
    Medford, Wisconsin
    If you want a car that well engineered, you don't buy a Pontiac. I don't mean this to slander the engineers at Pontiac in any way. There is a price point they are engineering to. Same goes for an XJ.
    So how's the handling with that extra down-force you're getting off that spoiler?
  19. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I loved my '94 GrandAM ;) best car i ever owned.
    And the cruise wasn't stupid like a lot of them today. Go up a fairly good hill, it would wait and see if it had to change gears before just randomly dropping 2 gears cause it lost 2km/h lol.
    I hate the transmission in our 2005 Escape. It will drop to OD as soon as i reach 70km/h even if i've got the pedal half way down. I mumble profanities every time it does it lol.
  20. wamaxim
    wamaxim Active Member
    Vancouver, USA
    If Schooter wants to kill his cruise control by installing a high performance cheesy accessory then he should just do it. If I read his original post correctly the fact that his cruise control didn't work wasn't ruining HIS life. He had gotten used to the fact it didn't work. It was bugging his DADDY-O! Schoot, you shoulda told your old man that if he wanted it to work so badly then he's welcome to pay to have it fixed! BTW Daddy-O, the cheesy accessory stays. If it's so important to you to have the CC work then pay for a work around! 'Nuff said!
    If you want your hair to turn white over this type of issue i.e changed from incandescent to led lighting and everything quit working just google CANBUS It is used on some motorcycles now and more cars than bikes. This is going to be an "I just got my a$$ kicked" technology unless we, as consumers, are going to be empowered to easily program threshold voltages etc from a pc.
    Woe the day,
    Loren
  21. mhajicek
    mhajicek New Member
    Wamaxim, I think I'm seeing a market for aftermarket replacement electrical systems...
  22. wamaxim
    Vancouver, USA
    Possibly so. Or an opportunity for enterprising young folks to develop programming tools and interfaces so that individual thresholds can be adjusted to allow add ons to function within the CANBUS system. Hmmmm..........
    Loren
  23. Robert
    I LOVE my Pontiac. Of course I should preface that by saying they haven't built a decent car since 1970 (sorry you Trans Am fans, I'm not budging on that one). Schoot, I hear your annoyance (or more so your father's), but it isn't any great suprise to hear of these problems. Car systems are so stinkin' integrated these days that you can't just patch stuff in like we all used to. At my last job, we fought for months to get a car to work right as we had to have each and every part we sourced recoded at the stealership ($90 a pop) so that the car would accept the part and not lock up. And we had a fair number of parts. What a hassle. This included the windshield wiper reservior. Thank heavens we still don't have to give a DNA sample to get into the machine...
