Idle ajustment screw not making a difference
Discussion in 'XJ Technical Chat' started by mikegustus, Aug 31, 2009.
  1. mikegustus
    mikegustus Member
    Los Angeles
    My bike is idling pretty high, adjustment screw isn't making any difference. If I turned the screw too many times one way or another, does it disconnect or come out of whatever it is screwed into between the carbs? any ideas?
  2. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    hi Mike,
    The idle screw has pretty fine threads for fine tuning in your idle. Yes if you screw it to the left to far it will come out but no biggy just screw it back in.
    Now if your idle doesn't go down when ya back out the screw have you tried putting more slack in the throttle cable?
  3. mikegustus
    mikegustus Member
    Los Angeles
    that was it, give the throttle cable some slack and it seems to be normal again. thanks a lot, gotta love the simple fixes. rookie mistake on my part.
  4. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    hey we were all rookies at one point. When I first got my bike I thought the cable WAS how you set the idle :lol: that's why l suggested to check it. :)
  5. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    guilty on this one too
    the guy that showed me the idle adjust screw now has me WORK on his bikes! I have learned so much here just reading and absorbing
    :lol:
  6. CJ06XLT
    CJ06XLT Member
    Southwick, MA
    My idle adjust screw didn't work either. Then I pulled the carbs off and found out that the PO had backed the darn thing out about 1/2". After a zillion turns it finally has an effect on the idle!
