Idle Mixture Screw Cap
Discussion in 'XJ Technical Chat' started by Fishmaster, Nov 29, 2008.
  1. Fishmaster
    Fishmaster Member
    Spring, TX
    Why the Toshiba carbs idle mixture screws comes capped?
    Did the engineers think that the carbs will never need to be rebalanced?
    How do you guys usually remove them?
    Are they located right next to the choke plunger, right?
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    You mean Hitachi?... These bikes were set a tad on the lean side at the factory, lean enough to pass EPA regulations... then they capped them off so owners didn't "tamper" with the mixture settings therefore making the bike out of compliance with EPA.
    My favorite way of removing them is to drill a small hole (1/16" or 3/32" bit) through the cap, being careful not to plunge the bit and damage the idle screw, and use a sheetrock screw to pull the plug out... and you're right, they're next to the plungers.
  3. Fishmaster
    Fishmaster Member
    Spring, TX
    sorry I "mixed" the japanese makers
  4. Fishmaster
    Fishmaster Member
    Spring, TX
    stereomind,
    how thick is the cap?
  5. MiCarl
    They're quite thick. They're not little sheet metal hats, but a brass disc. I've never measured one but I'd say 2-3mm thick.
    The key is to use a small, sharp bit at high speed so you're not using much pressure. You'll feel it punch through. If you're leaning into a big, dull bit it'll bugger the head of the mixture screw when it breaks through.
  6. Fishmaster
    Fishmaster Member
    Spring, TX
    So the screw head is not touching the cap piece, right?
    In my carbs they look like aluminum.
    Tthank you guys, I will try with my Dremmel. I hope they come out easy with out damaging the screws.
  7. wizard
    Hi fishmaster, I spent an hour yesterday trying to find your carbs, I also spent some time trying to find an '86 XJ700N, I did find an '85.
  8. Fishmaster
    Fishmaster Member
    Spring, TX
    Wizard, the owners manual shows XJ700N-XJ700NC and the manual edition is from 1984. Maybe you're right and is a 1985. My brother in law purchased the bike in 1986. I don't know how to upload pictures to show you the carbs
  9. Hack
    Hack Member
    Ontario, Canada
    So, once the "caps" have been taken out to do the adjustments with the colortune, does anyone ever cover the opening afterwards to keep out dirt, etc.? I understand that they were initially installed by Yamaha to prevent tampering, but they also kept out crud. Maybe not an issue?
  10. wizard
    They don't need to be covered, in fact it's PITA if you want to have a fiddle, I mean tune. :lol:
