Ignition Coil Replacement
Discussion in 'XJ Technical Chat' started by kookie31, Mar 14, 2011.
  1. kookie31
    kookie31 Member
    Arizona, USA
    I have a 1983 Yamaha Seca 750r. While working on it, it fell over and smashed the #4 spark plug cap. My question is do I need to replace the whole ignition coil or can I just replace the cap. The coil is 12v CM12-09. Thanks for any information.
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    You should be able to just replace the plug cap on the wire.
  3. bigfitz52
    The caps unscrew from the end of the wires; you can replace just the cap. Be sure to get a correct cap, to match the other three (the bike uses resistor caps.)
  4. kookie31
    kookie31 Member
    Arizona, USA
    thanks for the help. another question: what size are the caps? i was looking around and i see some that are for 10 & 12mm and another one for 14mm. which ones do i use? thanks again
  5. bigfitz52
    Your bike has 14mm plugs.
  6. kookie31
    kookie31 Member
    Arizona, USA
    once again thanks
