Ignition problems
Discussion in 'XJ Technical Chat' started by SecaDan, Jun 3, 2008.
  1. SecaDan
    SecaDan New Member
    Appleton, WI
    I am working on reviving my 82 Seca after a 2 year slumber, I pulled and cleaned the carbs so thats not an issue. I have no/weak spark on cylinders 2&3. I tested the coil and I think its bad. Honestly, I am a moron when it comes to electrical systems. If its mechanical no problem. So I can't say I am confident about my testing procedures. However I did pick up a coil from a local cycle salvage. Assuming the coil isn't the issue, what would be more likely to go the CDI or pick up coils and how do I test? I have the Haynes manual but like I said, electric systems and me .. not so good. Thanks for the help
  2. RickCoMatic
    Swap the Plug-in's from the Coils to the wiring harness and see if the problem switches to 1 and 4 ...
    If is does you have a good idea that the Coil is involved.
    Can you use a Teat Light and a Multi-meter OK?
    We could walk you through a few diagnostic tests.
  3. Polock
    do your electromechanical stuff first, plug in the tci 3 or 4 times take the coils off and shine up the mount points, if the sparkplug caps unscrew snip off 1/4 inch of the wire and screw them back on
    just go over it and make everything clean and tight and see if that helps
  4. SecaDan
    SecaDan New Member
    Appleton, WI
    I never really learned to use a multimeter too well. I get the basics but thats about it
  5. Robert
    Oh Kenbo... Here is your chance. Dan, contact Kenbo, I think he just posted a how-to recently. If it isn't in the system, I'm sure he'll hook you up with a good file that will help you out.
  6. SecaDan
    SecaDan New Member
    Appleton, WI
    thanks for the clue, I watched the youtube video and that helped quite a bit. So now I replaced the coil and I have spark at all four plugs. Now I need to get a couple new plugs and I can give it a try.
    Next question is should I go to a hotter plug? I am using the stock NGK BP7ES, is there an advantage to switching to the BP5ES?
  7. chacal
    No advantage to a hotter plug, in fact, it's a dis-advantage. Stock with the stock plug, if everything else within the system os okay stock plugs work just fine!
  8. Robert
    I caught the "tube" video too. While they didn't have me laughting too much, they weren't boring. Good video for folks with questions.
