ignition switch question
Discussion in 'XJ Technical Chat' started by jcoy44460, Apr 26, 2009.
  1. jcoy44460
    jcoy44460 New Member
    hey i just got a 86 maxim s with 9000 miles on it...i noticed today when you move the ignition key when its running the back tail light with go off and on...it is kinda sloppy so do you think it just needs a new ignition switch..thanks
  2. JoeFriday77
    JoeFriday77 Member
    North Texas
    You might want to pull it off and inspect it first. If it's spent time outside, there could be corrosion in the switch.
  3. jcoy44460
    thanks,i will check it out
  4. bill
    bill Active Member
    Raleigh, NC
    More likely you have bad connections to the tail light. Most of the harnesses will have bullet connectors for rear turn and tail lights. Check those and check your bulb sockets. Could just be loose bulbs too.
  5. jcoy44460
    dont see any loose connections,just in case does anyone make after market switches that will work for this bike...they want 144.00 bucks for and oem switch....the after market switches i have seen do not match my numbers..they seem to fit every other bike but the 86 and 87 maxims...dont make any sense to me...?
