I'm going crazy!!
Discussion in 'XJ Technical Chat' started by Xj Bobber, Jul 13, 2015.
  1. Xj Bobber
    Xj Bobber Member
    ohio
    I have a 82 xj550 and i cant figure out why its not getting spark. I have replaced the coils with new/ used ones because i thought the old ones were bad. everything seems to be getting power i used my test light. Is there a possibility it could be the cdi box??
  2. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    Did you test the coils per the specs in the manual?
    Are your plugs good / the right ones?
    Is it no spark on all cylinders?
    Only suspect your tci after all other options have been ruled out (at least thats what the manual suggests)
  3. Xj Bobber
    Xj Bobber Member
    ohio
    I checked the coils with a cheap reader they were throwing out 2 to 2.3 oms. i dont have a manual that would help alot.
    yes they were working fine before i cleaned them i didnt change the gap at all. they were getting a strong spark.
    no there is no spark off either coil.
  4. Rooster53
    Be sure you are checking the spark correctly per the wasted spark system. For example, when testing for spark on #1 cylinder, the #4 cylinder plug wire must be connected and both plugs must be grounded to the head. Same for #2 and #3.
    Here is a good link on the theory of the wasted spark system and troubleshooting no spark:
    http://www.xjbikes.com/forums/threads/how-to-ignition-troubleshooting.21932/
  5. Xj Bobber
    Xj Bobber Member
    ohio
    Would that work for the screw driver test?
  6. Beekman
    Erin, Ontario
    You've lost me here, you cleaned your plugs and now you have no spark?
    Be more specific, would what work for the screwdriver test? (By screwdriver test i assume you mean shorting across solenoid?)
  7. Beekman
    Erin, Ontario
    Read the link rooster posted, it gives explicit steps to test if no spark on all 4
  8. Xj Bobber
    Xj Bobber Member
    ohio
    i cleaned the plugs after i lost spark. the screwdriver test is you put it in the wire and hold it close to the head and see if your getting spark from the coil.
  9. Beekman
    Erin, Ontario
    Ohhh okay, have you tried testing with the plugs and caps properly installed on the "new" coils?
    If not, try reinstalling it all to the coil wite and making sure the pair of plugs in question (1&4 or 2&3) are properly grounded to the head.
    I feel like based on what rooster explained that the lead you are testing via that method may not be getting grounded to the head.
  10. k-moe
    That particular test is really not a great idea when you are testing a TCI ignition system.
  11. Xj Bobber
    Xj Bobber Member
    ohio
    I have Beekman i still get the same result I printed out that link im going to go through the steps on it. what will it cause the tci system to do k-moe?
  12. k-moe
    There is the (high) potential to damage the TCI if there is an insufficient path to ground on the secondary side of the coil.
  13. Xj Bobber
    Xj Bobber Member
    ohio
    Well thats just great... so i guess im screwed then. So this brings me to my next question. can i use a 650 tci on my 550?
  14. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Does the bike crank over and how is your battery voltage while cranking? if your battery is marginal and the voltage drops under
    10 volts its possible that you would not have any spark under those conditions.
    Next is to find a wire diagram and test the side stand relay to see if it has power going through it for the ignition circuit.
    Fitz is the 550 guy and he knows better than I do on how the power gets to the ignition circuit/TCI
    dragsta likes this.
  15. jamings67
    jamings67 Member
    CT USA
    Check the wire that comes from the pickup coils on the LEFT side of the engine to the TCI
  16. Xj Bobber
    Xj Bobber Member
    ohio
    Yes it cranks. I was reading a thread last night about the volts being to low causing no spark that is going to be the first thing i do is pull the battery and put it on a trickle charge.
  17. Xj Bobber
    Xj Bobber Member
    ohio
    i chased that wire everything looks good with it.
  18. XJ550H
  19. Xj Bobber
    Xj Bobber Member
    ohio
    ok thanks. Hopefully with all this info i'm getting from everyone i cant track it down and start growing my hair back!
  20. k-moe
    Juping to conclusions is not allowed. We have yet to be sure that the TCI is at fault. In fact we are very far away from reaching that conclusion.
    Have you checked the primary and secondary resistances of the coils yet?
  21. Xj Bobber
    Xj Bobber Member
    ohio
    Haha ok. I've checked them im not sure witch one being primary or secondary it came out to 2 to 2.5
  22. Xj Bobber
    Xj Bobber Member
    ohio
    I wish one of you guys lived close enough to swing by and help me figure this out. :eek:
  23. Toomanybikes
    Tsawwassen bc
    Have you checked spark plug caps they are a big issue on many bikes that old should be 5 k ohms !
  24. k-moe
    The primary side is the small leads that feed the coils. Measure between them with the ohms scale set to x20.
    The secondary side is measured between the spark plug wires on each coil. Set the ohms scale to x200.
  25. Xj Bobber
    Xj Bobber Member
    ohio
    ok what should they be?
  26. jayrodoh
    jayrodoh YimYam
    Cleveland
    Where are you at in Ohio? I'm wife/kid free next week.
  27. Beekman
    Erin, Ontario
    From the xj4ever catalog (more than just a parts catalog)
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  28. k-moe
    To add to Beekman's post, if you measure the secondary side with the caps in place you need to take into account the individual cap resistance specs. 11k ohms + (10k x 2) = 31k ohms.
    Beekman and Xj Bobber like this.
  29. Xj Bobber
    Xj Bobber Member
    ohio
    North of Dayton new Carlisle area
  30. jayrodoh
    jayrodoh YimYam
    Cleveland
    7 hr round trip is a bit too far for me :D
  31. Xj Bobber
    Xj Bobber Member
    ohio
    Yea I'd say haha. You live by cleavland? Also I checked coils and caps all good. I have my battery on the charger.
  32. Xj Bobber
    Xj Bobber Member
    ohio
    I got it!!!! She's alive!! I'm embarrassed to say it was my battery not having enough power :oops: but anyway thank you guys so much for all your help! :D
  33. Beekman
    Erin, Ontario
    Ive been there haha the important thing is what you learned on the way!
  34. Xj Bobber
    Xj Bobber Member
    ohio
    I shouldn't have thought the worst from the get go. Although that battery isn't that old. :/
  35. Beekman
    Erin, Ontario
    Yes one thing i have learned here is to slow down and not jump to conclusions. Often the principle of occams razor is applicable with these bikes... the simplest solution can often be the correct one!
    Xj Bobber likes this.
  36. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    All too often.....the battery is usually the culprit......
  37. Xj Bobber
    Xj Bobber Member
    ohio
    I haven't been able to ride her for about three months. It was driving me insane! It never crossed my mind to check the battery.
  38. k-moe
    Not trying to be mean, but...
  39. Xj Bobber
    Xj Bobber Member
    ohio
    T
    That's why i went ahead and threw it on charge while i went over everything with the multimeter.
  40. k-moe
    At least you didn't waste any time by making sure the coils are in spec. One less thing to worry about.
  41. Xj Bobber
    Xj Bobber Member
    ohio
    What do you mean? i checked both primary and secondary on the coils while i was charging the battery.
  42. k-moe
    I mean that checking them was a good thing to have done. You now have a working baseline of what the coil condition is should you have trouble in the future. This is no different than checking valve clearances to see where they are. It's all part of a good preventative maintenance program.
  43. Xj Bobber
    Xj Bobber Member
    ohio
    Oh ok i see what your saying now haha. i also have a spare set if i ever need them. I was a dummy and ordered them because i did research and evidently the guy didn't know what he was talking about.
  44. Xj Bobber
    Xj Bobber Member
    ohio
    He said if the coil dropped below 3.2 oms it was no good and to replace them.o_O
  45. MN-Maxims
    Saint Paul, MN
    Bobber,
    The heart of your bike is the battery and charging system. Make sure you fill the battery with distilled water and slow charge it and test the voltage\
    after charging. Then test the output of your charging system at or above 2000 rpm. You should be looking at least volts at that rpm range. I have seen one of my bikes at 14.8
    A good healthy battery and charging system will make a lot of running and starting issues go away. Just remember lots of power the better the ignition works.
  46. Xj Bobber
    Xj Bobber Member
    ohio
    This should have been priority one. I have no clue as to why i didn't think of it.
  47. Xj Bobber
    Xj Bobber Member
    ohio
    Does anyone know where the alternator is located on my bike?
  48. k-moe
    There is a big round cover on the left side just behind the #1 cylinder and above the shift lever cover. Behind that cover lies the alternator.
  49. Xj Bobber
    Xj Bobber Member
    ohio
    Ok thanks is there maintenance that is or should be done to it?
  50. Xj Bobber
    Xj Bobber Member
    ohio
    Mine looks kinda rough
