Instrument mod.
Discussion in 'XJ Modifications' started by a100man, Sep 15, 2014.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi Folks
    After several evenings with a drill and a modelling knife I made the electronic rev-counter from a FZ400 fit the Seca 550 cluster - well sort of - as you can see it's a bit 'twisted'. With only two m4 studs to play with and holes drilled into the bevelled cable entry it's rather a PITA.
    Anyhow also made the needles all one colour which I was in there..
    looks better in real life. The point of all this was/is to run a Radian engine which lacks the mechanical tacho drive.
    Cheers
  2. skrewflanders
    skrewflanders New Member
    Sandy, UT
    Doesn't look too bad, good job. Speaking from personal experience, those needles can be very easy to break!
  3. a100man
    Bedford, UK
    Ah yes I had a near thing with the fuel gauge needle that I accidentally bent. Part of the reason for repainting them with some
    fluorescent orange paint.
    Cheers
