Interesting swap
Discussion in 'XJ Technical Chat' started by hogfiddles, May 20, 2020.
  1. hogfiddles
    Ok, so here’s a swap I would not have thought about or try....but on the 700n that I’m taking apart, the collector box is from a 650rj. It is totally installed ON the bike. So we know that the 650rj collector box will fit on the 700.
    here’s a pic-
  2. Toomanybikes
    Tsawwassen bc
    So based on that will a 700 box fit on the 650rj ?
  3. chacal
    Hmmm, that's interesting, because both the input and output gaskets of the 650RJ collectors are a significantly different size (both ID and OD) from the XJ700 models:
    Header pipe inlet to collector:
    OD: 32.47mm
    Length: 29.71mm
    Material: fiberglass wrapped copper
    Applications:
    XJ550 all headpipe to collector (4)
    XJ650 Seca headpipe to collector (4)
    XJ650 Turbo headpipe to collector (4)
    XJ750 all headpipe to collector (4)
    OD: 37.67mm
    Length: 30.20mm
    Material: graphite
    Applications:
    XJ650 Maxim/MM headpipe to collector (4)
    XJ700 all headpipe to collector (4)
    XJ750-X headpipe to collector (4)
    XJ750RL headpipe to collector (4)
    XJ900 S/SH headpipe to collector (4)
    Collector outlet to muffler:
    OD: 44.00mm
    Length: 24.90mm
    Material: graphite
    Applications:
    XJ550 all collector rear to muffler inlet (2)
    XJ650 Seca collector rear to muffler inlet (2)
    XJ750 Seca collector rear to muffler inlet (2)
    XJ750 M, MM collector rear to muffler inlet (2)
    XJ750RL collector rear to muffler inlet (2)
    XJ900RK, RL, N/FN all collector rear to muffler inlet (2)
    XJ1100 headpipe to collector (2)
    XS1100G headpipe to collector (2)
    XJ1100 collector rear to muffler t (2)
    XJ1100 muffler crossover pipe (1)
    XS1100G muffler crossover pipe (1)
    OD: 40.73mm
    Length: 29.90mm
    Material: graphite
    Applications:
    XJ700 all collector rear to muffler inlet (2)
    XJ750-X all collector rear to muffler inlet (2)
    XJ900RK, RL, N/FN, F headpipe to collector (4)
  4. hogfiddles
    So I guess I will be looking at the joints themselves and see if mods were done
  5. hogfiddles
    I had a chance to take a quick peek—- the mufflers:
    1. had the gaskets removed
    2. had the retaining rings removed and had the worm-Drive band clamps on instead ( but they are not visible in the pic as they were cover by the shields)
    I will say that it was a good snug fit! Even with clamps loose they were just as snug as any other mufflers I’ve removed.
    I’ll update when I get to the exhaust pipe ends.
