Is it a good Idea to go to a machine shop?
Discussion in 'XJ Technical Chat' started by carlos102090, Jul 15, 2011.
  1. carlos102090
    carlos102090 Member
    I've been working on my carburetor all day and have only managed to clean one section of it because I CANNOT take out these float pins from hell. I am afraid that I will eventually break my "towers". Could a machine shop do a better job at just removing the pins so I can do the rest of the work? wise idea?
  2. mirco
    mirco Member
    LaGrange Ohio
    I have a machine shop. Do yourself a favor and go get a propane torch and heat them up and they will come right out. You will save yourself $100. It will take about 5 minutes total.
  3. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Where are you located? Maybe there's an experienced XJ'r near you that could help.
  4. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    granted all an experienced machinist would need to do is give that pin a dirty look and it'll fall out but really, you oughta be able to get it w/o too much trouble. ya know they usually are only supposed to come out one side OR the other right? but that age and wear lets them come out either side so nobody notices.
  5. carlos102090
    carlos102090 Member
    I live in Austin Texas
  6. Rice_Burnarr
    Rice_Burnarr Member
    Sorry Carlos, I'd be happy to help, but TX to the east side of PA is just too far...
    I saw your other thread, and I thought you got the pins out? Or was that just one pin out of four?
  7. gman
    gman Member
    Grand Rapids Mi
    I would say if your comfort level is a machine shop, then go for it.
    I just had a similar experience working on my carbs. It was not going well and was thinking,
    I should really take this to someone who does this for a living. Instead I ended up breaking a float tower and set my project back.
    Hindsight I would of been better off going to a shop.
    It's your project do what you feel comfortable with.
  8. carlos102090
    carlos102090 Member
    Yea i just got one of the four out hahaha. I'm going to try the propane torch (saw one for 20 dollars). If it doesnt work I'll go to the shop :(
  9. Rice_Burnarr
    Rice_Burnarr Member
    Here's a closeup of what you're dealing with. Take a close look and you'll see that the pin is a larger diameter right under the head. The other end is supposed to be a slip fit.
    So if you're going to try heat, you should only have to heat the post by the head of the pin. The other end should be a slip fit.
  10. TIMEtoRIDE
    GIVE UP on forcing or tapping it out.
    If you use a Dremel with a thin wafer (cut-off wheel) then you sacrifice the float pin and now have all the clearance to push the remaining stubs out.
    You take a cheap pair of pliers and cut one of the jaws (fork it for clearance)
    Gorilla-glue a short bit of pin to the other jaw, which presses the stub out.
    Don't risk breaking the float posts is RULE #1
  11. bigfitz52
    All that needs to be done is to support the end of the float tower on something substantial (block of wood with a hole in it works great) at the "head end" of the pin, and tap it out with a drift of the same size.
