Is my carburetor supposed to leak in this way.
Discussion in 'XJ Technical Chat' started by carlos102090, Aug 2, 2011.
  1. carlos102090
    carlos102090 Member
    I wanted to put some gas through my carb before I put it on the seca. When I put fuel through it and when the bowls filled up I noticed that gas was coming out of the exhaust connections (towards airbox/filter). Is this normal? If not, What should I do?
  2. wizard
    Gas running out the carbs is not normal, or safe, the float needles / seats are letting by. You can try pollishing them, or replace them.
    Also, if the float levels are wrong, they can flood, or the floats in upside down.
  3. RudieDelRude
    RudieDelRude Member
    Illinois (STL area)
    I think depends at what angle you had the carbs at when they were leaking.
    Float levels/needle not seating would cause the gas to more or less overflow.
    BTW if your petcock has a prime setting you dont need to fill em up before you put em back on.
  4. SQLGuy
    SQLGuy Well-Known Member
    It is not normal unless you were holding the carb really crooked.
    It is usually an indication that either your float needle is not sealing well to its seat, or the service fuel level (float height) is too high.
  5. automotivated
    automotivated Member
    Milwaukee, WI.
    float levels are off, just fixed the same exact problem on mine.
  6. RickCoMatic
    You'll have to do some Troubleshooting.
    Possibilities include:
    Petc0ck Leaking-by
    Carb Float Height -- Incorrect.
    Carb Float Seat obstructed
    Carb Float Seat Worn-out
    Carb Float Needle Sticking
    Carb Float Needle Geometry ... Needle cannot seat.
    Carb Float Needle "Solid-type" ... Worn
    Carb Float Needle "Viton-type" ... Worn or missing.
