Is this the cap to access Pilot Screw
Discussion in 'XJ Technical Chat' started by nammy, Aug 3, 2007.
  1. nammy
    nammy Member
    Upstate New York
    I still can't find the location of the cap that hides the Pilot Screw.
    Is the only 1 per carb?
    85 Maxim X 700
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Re: Where is the cap to access Pilot Screw
    Yes only only one per carb and is it on top beside the choke plunger. Some bikes have already had them removed by a PO.
  3. nammy
    nammy Member
    Upstate New York
    Is this the cap I must remove?
    [​IMG][/img]
  4. samsr
    samsr Member
    Colorado Springs
    That would be the one. Be careful drilling. You just want to get through the plug. DO NOT let the drill get away from you. If you do a pilot screw will be the only repair in a best case scenario. Worst case; carb body. good luck. I use a 3/32 drill bit then screw in a drywall screw and pull straight out. Take a bit of muscle but out it comes.
  5. nammy
    nammy Member
    Upstate New York
    Thanks, I was tempted to remove but wasn't sure. Off to the garage I go...
  6. nammy
    nammy Member
    Upstate New York
    Thanks SamSr
    Got it done, just need to put it all back together now ;)
