It's Alive!!!(an update)
Discussion in 'XJ Technical Chat' started by JoshL, Apr 27, 2009.
  1. JoshL
    JoshL New Member
    St Cloud, Fl
    I haven't posted very often in the forum since I usually find the answers I need by searching through other posts, so thanks to all.
    I've been restoring my xj650rj for a while now and here's where I am so far.
    Replace cylinder jugs (original was cracked)
    new pistin rings
    new gaskets and o-rings all around
    valves lapped and clearances set to spec
    carbs cleaned(zestfully) and rebuilt with new throttle shaft seals ond o-rings, and bench syched
    Yesterday was my first chance to try out my "new" carbs and after sitting for a few years in somebody's shed it sprang to life as if it came off the assembly line last week.
    I still have lots to do (wheel bearings, steering head bearing, complete rebuild/replacement of the brakes, tires, etc, etc), but I'm getting there slowly bur surely.
    Sorry this is a bit lengthy, but thanks to all again
    Josh
  2. sushi_biker
    sushi_biker Member
    Damn, good job man!
  3. Tman_74
    Tman_74 Member
    North Ridgeville, OH
    I bet everything will fall into place now that you can hear it scream!!!!!
    Great JOB!!!!
  4. ktcubed
    ktcubed Member
    St. Augustine, FL
    Wow, mouth to mouth for a motorcycle...
  5. JoeFriday77
    JoeFriday77 Member
    North Texas
    Great work. You have shown extreme patience in going through everything in great detail.
