jet needle hsc33
Discussion in 'XJ Technical Chat' started by denbola, Apr 6, 2014.
  1. denbola
    denbola Member
    poole,dorset,england
    been having running problems when under load, just like a misfire, after removing carbs for the 3rd time found cyc2 spring loaded jet needle inside piston not returning ie spring not pushing it back to stop, rest working ok
    1) how would that make the engine run with one needle jet stuck in up position and why is it spring loaded ??
    2)the next thing is what size main jet should i fit when changing air filters to k&n type size now is 107. ??
    hsc 33 1985 xj700n
    many thanks mike t,
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I would keep it as stock as possible. Changing the filter is going to cause more problems than it's worth. I had a foam Uni filter installed by po and went back to the stock filter and it runs better. The engineers that designed and built the bike knew what they were doing.
