Just got a new motor
Discussion in 'XJ Technical Chat' started by On1wheel01, Jun 15, 2007.
  1. On1wheel01
    On1wheel01 Member
    Nc
    Ok guys my search for a replacement motor is finally over. I went to the local salvage yard today and picked up a 82ish seca yics 750 motor, carbs and exhaust. Spent $400 but I fig it wasnt to bad a deal? Eh but I'm not sure. So I'm gonna put it in prob this winter or until my tranny gives out. If you have any pointers to doing the change go ahead and send them. Thanx and wish me luck
  2. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    The TCI unit may be different.
    $400 seems fine.
    It is best to have 2 or 3 people to help with lifting the motor out and back in again, from the right side of the bike. The shaft bolts are fun to "break", get someone sitting on the bike in gear with the rear brake engaged. Oil filter cover off or it will not clear the frame.
    Good luck!
  3. On1wheel01
    On1wheel01 Member
    Nc
    TCI? What is that the igniter?
  4. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    Yeah, might be a slightly different ignition curve, more advance maybe, will not stop the motor going though.
  5. On1wheel01
    On1wheel01 Member
    Nc
    Ok so how do I know what year stuff this motor is?
  6. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    Post the first 3 letters/numbers stamped by the clutch leaver on the motor here.
  7. On1wheel01
    On1wheel01 Member
    Nc
    Ok it says 5G2
  8. Nick
    Nick Member
    Vernon, BC Canada
    Info from XJCD
    serial 5G2-000101 up to 150000 is from 1981 XJ750RK
    serial 5G2-100101 up to 100000 is from 1982 XJ750J
    serial 5G2-150101 up to 200000 is from 1983 XJ750RK
  9. On1wheel01
    On1wheel01 Member
    Nc
    Ok it seems it's a 81 xj750rk. Is that a good thing? What is the diff between them. I am assuming it is a seca motor as I was told by the owner of the yard.
  10. On1wheel01
    On1wheel01 Member
    Nc
    Oh yea should I get a 750 tci or will the 650 be sufficient.
  11. Nick
    Nick Member
    Vernon, BC Canada
    I don't know the difference between these engine models, I have an 82 model and all I know is hang on when you crack the throttle.
    I would suggest you find and use a 750 TCI.
  12. On1wheel01
    On1wheel01 Member
    Nc
    Got a ? bout the 750's performance. How does it do against a 650. And can you bring it up in 2nd? My 650 would come up in 1st but now way in 2nd. Just hoping for more power.
  13. Nick
    Nick Member
    Vernon, BC Canada
    I don't try to "bring it up" assuming you mean a "wheelie".
    I know of one XJ650 in the next town but haven't gone riding with him to see how these bikes perform.
    I had a bit of "fun" with a Mustang and was very pleased with my bikes performance.
