Lean verses Rich
Discussion in 'XJ Technical Chat' started by lpayne, Sep 2, 2008.
  1. lpayne
    lpayne New Member
    Oklahoma City, OK
    Can someone tell me the differences in how my Xj650 would react with carburators running lean verses rich?
  2. TheHound
    TheHound Active Member
    Scotia, NY
    Do a search for plug chops.
    It will tell you if your rich or lean.
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    If they're running lean, generally the bike is harder to start, runs quite a bit hotter, can miss, if it's lean enough, it can blast (weld) a hole in the middle of the piston.
    It's generally the worst side of the lean/rich scale. Running rich won't seize your engine :)
    Lean also makes more power than rich, but you sacrifice the power to save your engine.
    Running just a TOUCH rich is generally good, cause you get better combustion, the more volume of gas cools the engine, easier starts, runs better (no misses)
    Running VERY rich can be bad, because you're wasteing fuel (bad fuel economy) carbon deposits form more abundantly, it's bad for the environment (emmisions). Rich = not as much power as an optimally adjusted mixture.
    I see in your sig you're running 4 into 1 exhaust, this type of configuration will make your bike breathe better, or create better air flow, which usually means you're gunna be running lean. This may mean you have to adjust your pilot mixture, or it may mean you have to rejet your carbs.
    I'm sure some others will add to these points :)
  4. lpayne
    lpayne New Member
    Oklahoma City, OK
    I'm actually running 4 into 2 exhaust. Also I'm going to check out the plug chops issue to see for sure, but, I think I'm running a bit rich.
  5. wizard
    yank the plugs & post a pic', you will get an abundance of opinion.
  6. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    KrS14, nice!
    been doing your homework, what he said ^^^
  7. KrS14
    KrS14 Active Member
    St Marys, Ontario
    LOL sorry lpayne, i was looking at TheHound's sig not your post hahah (headers)
    my bad :)
