left key on,battery went flat.
Discussion in 'Hangout Lounge' started by ken007, Nov 14, 2010.
  1. ken007
    ken007 Member
    Brisbane, Australia
    yesterday went for a decent ride,120km's,when i got home i left the key on and to the best of my knowledge the only light on was the green nuetral light. it would have been on for 4 or 5 hours,surely this couldnt drain the battery or are there other explainations ? i ride the bike everyday so the batt should have been fully charged.
  2. Zookie400
    Zookie400 Active Member
    Connecticut
    having the tci powered will drain the battery, and the light helps as well. check the water levels and charge it back up, see if it goes dead again.
  3. ken007
    ken007 Member
    Brisbane, Australia
    thats what it must have been zookie,i gave the battery a couple of hours charging and it started straight up,after not checking the battery for a month i had to top the water up a bit.just went up the highway for half an hour so will see if it starts just as easy this arvo, thanks
  4. ken007
    ken007 Member
    Brisbane, Australia
    battery all good again and starting straight up
  5. Zookie400
    Connecticut
    SWEEET!
  6. seaguy
    seaguy Member
    Coastal,AL
    I have done the same thing. I think my neutral sw is iffy. Sometimes that green light will be off regardeless and I have to clutch it to crank up. Easy to leave the sw on when the short term memory is slipping.
  7. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Do certain models NOT turn on the head light with the key (non running)? Or did you install headlight switches?
    I drained mine shortly after buying it by putting it in "Parking Light" mode instead of just locking the wheel.
    I still don't quite understand the concept of "parking" your motorcycle in Europe with the lights running indefinitely (especially before the invention of LEDs).
  8. iwingameover
    iwingameover Active Member
    Mine does not turn the headlight on until it starts. It stays on until the key is turned off.
  9. ken007
    ken007 Member
    Brisbane, Australia
    the light on mine doesnt come on till i turn it on,its a 650 special,with my mates new bike the light comes on automatically,he doesnt have a say in the matter.
  10. Ravenz07
    Ravenz07 Member
    Ya mine doesnt start until it turns over really. Its like it has a system that attempts to use most energy for the initial start.
