Looking for a write up
Discussion in 'XJ Technical Chat' started by johnsmithx1974, Apr 10, 2014.
  1. johnsmithx1974
    johnsmithx1974 New Member
    Indiana
    Bought a1985 Yamaha xj700 maxim n, looking for a write up on what to check on the bike. So far I've cleaned the carbs.
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    This applies to any old bike.
    http://www.dansmc.com/mc_repaircourse.htm
    Specifically, check your valves, brake lines, rear brakes shoes, change oil, thoroughly clean carbs, check tires, check front brake pads calipers and master cylinder, clean and repackage wheel bearings, lights and electrical system. Lots of little things add up to a safe machine.
  3. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    New fusebox, preferably the modern ATC type.
  4. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    The 700's do not have the old school fuse boxes prone to failure, They already have blade fuses.
    In addition to what was mentioned above: fork seals/oil, steering head and swingarm bearings, check petcock for functionality, tank for rust, inline fuel filter
