looking for jig plans to chop maxim to bobber
Discussion in 'XJ Modifications' started by xj750problems, Mar 15, 2012.
  1. xj750problems
    xj750problems New Member
    recently got given a non running 82 yamaha xj750 maxim, interested in chopping to bobber. can anyone with tips info or even jig plans how i can turn this all original into a mean machine help out, losts of awesome pics ive seen on forums, lots of knowledge. hope someone can help me out.
    also on another note looking for any schematics for the bike.
    wanna work on this and have it running. hasnt ran in 5 years and has been sitting, replaced battery and all i got were lights.
    so any personal messages would be greatly appreciated or even emails.
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Before you start cutting and bobbing your bike it would suggest to get it running first. Go through everything and get it right . That way you will know everything works. Go through the carbs, adjust valves , brakes and electrical stuff. That way you will know if anything needs to be replaced or repaired.
    You probably won't find and plans since most bobbers are a costom project. Look for ideas from other members and use the ones you like.
  3. xj750problems
    What would be the most common problem for not starting?
    Ive replaced the battery,spark plugs and fuses.
    Dont know if I should troubleshoot some wires or directly replace relays and coils.
  4. mlew
    Apex, NC
    For a bike that has been sitting the most common problem is dirty and gummed fuel ststem. The tank and carbs have old fuel that has turned to varnish and plugged everything up. They will have to be taken apart and cleaned.
    Don't start replacing parts just because you think it might be bad, that can get expensive and frustrating. Get a manual and start reading through the trouble shooting section. Test parts before condeming them.
    Put your location in your signature, there might be a member nearby that can offer some one on one help.
  5. xj750problems
    Thanks. Im definitely gonna try that out
    What would u recommend would be an amazing cleaner?
    Cuz I know that some cleaners can leave an oily residue.
  6. mlew
    Apex, NC
    My favorite carb cleaner is Berryman Chem Dip. Most autoparts stores have it. It comes in a 1 gal can with a handy basket for dipping. It will eat any rubber so a complete carb dissambly is needed. Spray type carb cleaner is al the same to me, it also eats rubber so be carefull with throttle shaft seals and carb slide diaphrams. I always give carb parts a final spray down with brake cleaner it does not leave any residue.
  7. streetbrawler750
    streetbrawler750 Member
    Minnesota
    I just did the pine sol trick. Worked great to remove the years of grease and gunk externally, I question its ability to really clean the internal passages.
  8. mooch
    mooch Member
    Dayton, Ohio
    The Berryman Chem Dip works great, that's what I use. Just remember to remove ALL of the rubber o-rings and such because it will eat the rubber.
  9. hogfiddles
    If you're just trying 'start' it, do you mean it's not even turning over, or it turns over but doesn't fire up?
    Doesn't fire up........could be coils, tci, wires, relays, switches......anything electrical. If you KNOW you have spark and it's not firing up, then you know it's fuel-related. Either way, you have a lot of work ahead of you.
    If it doesn't even turn over, then you have to check your ignition switch, your right hand control...... in there is a little button w/ contact, gotta make sure that's all clean. There's a three-way switch on top---- OFF, RUN, OFF gotta make sure that's clean, and on RUN to work. You may need to pull the headlight out and check all the connections in there. Again, you have lots of work to do.
    Can you please write back and give us more in-depth, picky, details of exactly what you have tried to do?
    Dave
  10. TIMEtoRIDE
    Top of your list items -
    * Compression test
    * Valve lash check
    * Carbs "gone to Church"
    * Brake inspection and re-do
    * Tire Date Code check
    All done before cutting the frame - oh yeah, and process the title, too.
    There's some killer chops on this site !
