Looks like a clean one
Discussion in 'For Sale, Trade/Swap, Wanted' started by dmccoach, May 27, 2012.
  1. dmccoach
    dmccoach Member
    NE PA
  2. mtnbikecrazy55
    daymn. nice find!
  3. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    All original... except for the speedo (should be an 85mph model), and the rear rim, and the front rim, and the rotors (all from the 650 Turbo).
    Might not be a bad thing though, could mean that the brake lines were already replaced. Hard to tell without a close up pic.
    More than likely has some pretty tight valves with that mileage.
    Nice find for the price though.
  4. wwj750
    wwj750 Member
    central minnesota
    I wanna try & go for it, anybody have an idea what shipping to Minnesota would run?
  5. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    More fun if you check with the dealer to make sure is in running condition, such as valve clearances and such, and then go pick it up and ride it home ...
    You could call some freight companies and get a quote. Know any long distance truck drivers? Perhaps you could find one to put it on a load and bring it back with them for a minimal cost?
  6. tskaz
    tskaz Active Member
    I'd guess $500-$700, IF the guy would crate it up for you.
    Cheaper just to rent a trailer and spend a couple days driving down and back.
  7. wwj750
    wwj750 Member
    central minnesota
    See the deal is-Im not as much concerned in the running condition, cause the 650 Seca is the platform for the next build I wanna do. Going by the pics alone Im not afraid to gamble $500 cuz I can see everything is there that I need. I plan on going thru everything regardless.
    However, it would appear I may have jumped the gun on this decision on this one. as the Chief of Operations around here apparently doesnt share my enthusiasm about a new motorcycle at this time. She thinks I should wait to find one a little closer to home. So I agree, cuz this happens to me all the time-(seeing a bike I think I need & start making plans).
    So here it is folks-Im in the market for an '82 650 Seca, main concerns are a straight frame & forks, preferrably a motor that blows strong compression, for around $500. Its time to pull the trigger for the build Ive wanted to do for some time now. I hope a member here winds up with this one in the ad, sure looks like a good one.
  8. tumbleweed_biff
    Gahanna Ohio
    And I am pretty certain the one in the ad will go for well over $1k ...
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    dm,
    It is nice; however, I would not have known those things that tskaz pointed out that are not original parts. Got another question...that is a RJ right? Some members may not know the difference between a Maxim and a Seca.
  10. tskaz
    tskaz Active Member
    Yes, it is a 650R.
    Also has non-stock rear shocks, and those do look like the original front lines.
    Still a fine example of a stock 650R.
    Looks like all you'd have to do to it is change the fusebox, change the brakes, check the valves, and go through the carbs.
    It even has the original tool kit and chain/lock.
    My guess is around $1300
